Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
Hoover model U6476910 I was cleaning out the bearing sections of the brush when a spring type pressure washer fell on the floor. I did not see the washer when I took it apart and I can't tell where it goes in order to put it back together. It is very thin and measures about 5/8 inch with an 11/32 inch hole. Frank Nething
  • 1,675 Answers
Hi frank this sounds like its a compression washer, you normally find these on the end of the roller to even out any movement from side to side, as you look at the hoover's brush head, it should slip into a groove on one side with the roller...hope this helps
Posted on Oct 15, 2010
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
Reassembly of brush roll bearing/washers on Hoover Runabout
It will make no difference which direction those washers are installed, just that they are installed.
Jun 05, 2009 | Hoover Vacuums
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I used my Hoover FloorMate, SpinScrub Hard Floor Cleaner for the first time today. My intent was to clean the grout in my kitchen/family room floor. Since the water was dirty I know it cleaned the grout...
The Hoover model 800 has seperate brush assembly to do grout. The 500 model (yours) has only the one hight brushes so other means must be taken to do grout. I have a 500 and all tile floors and I'm bumbed too.
Kirk Thompson
San Juan,PR
Aug 14, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Lost roller on Savvy
need more info spring and washer don't tell me anything.do you have all the parts.i think your talking about the spring washer that keeps the brush roller from locking up.if thats what your talking about remove the bearing cap off the end of the roller brush.lay it inside the roller concave ppart of the washer down put the cap back on.if both washers came out of thesame side put the spring washer in first then the flat washer
Aug 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Middle brush problem
If this is new, get it replaced under warranty. Take your model number, serial number, proof of purchase and the brush block with you, or you may be able to do it at hoover.com.
May 25, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
I have a H3000 Floor Mat The problem is it want pick up the water after the scrub clean the floor. What could be the causeing the problem?
Hoover H3000 Floor Mat
I have a H3000 Floor Mat the problem is it won’t pick up the water after the scrub clean the floor. What could be the causing the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The problem could be that the Hoover H3000 Floor Mat could be clogged or something is blocking the suction port or you may have a pinched line of some type of which would cause it to not pickup, feel free to check with a local vacuum dealer in your area or in the yellow pages or the Hoover factory phone number is listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Water leaks
I removed the clean water tank to refill it and all the cleaning solution poured out onto the floor. Turns out a plastic pin with a spring and a rubber washer also fell out onto the floor leaving a hole in the bottom of the tank. Calls to Hoover and local repair center all ended the same with the need to order a new clean water tank for about $45 and two weeks for delivery. Went to my local True Value Hardware store and within a few minutes we found a workaround using two 7/16"x 1/4"x3/32" #780 Ring from Danco Inc. Pulled off the proprietary Hoover O Ring that had obviously failed and put two of these O Rings on in its place and so far it is working perfectly. Total cost $1.35. Would be nice if Hoover cared to take better care of their customers by offering this almost free and quick solution to the problem.
Oct 13, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
