Question about Visonic INC Smarthome SecureLinc Wireless Home Security System SecureLinc
How do i programme a wire free keypad to my visonic alarm panel?
    Sniper:
  • 58 Answers
Hi, first of all, are you sure its on the same frequency as your main module, 800 or 400? before I help further?
Mark
Posted on Dec 16, 2010
I have a dcs 1565 alarm, replaced battery but no lights or anything on keypad. Power is on
Switch off mains power and remove one of the battery terminals. Re-apply mains power. Keypad should give 3 beeps. If not, check that your AC voltage powering the alarm panel is between 16VAC and 20VAC, at the alarm panel. If this voltage is not correct, the power supply (transformer), is blown and requires replacement. If the AC voltage is correct, then measure on the alarm panel, where it says BUS R (for Red = positive), and B (for Black = negative). Voltage should be between 13 to 13.85 VDC. If there is no DC voltage present, either the alarm panel is blown, or there is a short circuit on your DC cables. Switch off the transformer again, and remove all cables from the Aux terminals on the alarm panel, as well as BUS (R). Label these wires! Switch transformer on again. Measure between BUS R (for Red = positive), and B (for Black = negative). Voltage should be between 13 to 13.85 VDC. If voltage is not present, the alarm panel is blown and requires replacement. The alarm panel does not have fuses that can be replaced. If the DC voltage is correct, wire the BUS R cables back in. Measure between BUS R and BUS B again. There may be a slight drop in DC voltage (less than half a volt), this is normal. Then go to the keypad. The keypad has a small screw on its underside. Loosen this screw completely, then pivot the keypad face upwards, until it unclips. Measure between BUS R and BUS B on the keypad. Voltage should be well over 13VDC, and close to what you measured on alarm panel. If there is no voltage present, the cable from keypad to alarm panel is damaged and requires replacement or repair. If your voltage is correct, and keypad still has no power, the keypad is faulty and requires replacement.
Dec 15, 2017 | DCS Home Security
The kit includes a line plug with 2 screws for wires. assuming it is a phone wire that is to be used which of the 4 phone wires should be inserted into the line plug.
Usually the green and red, but best way to find out is pop the phone port box where you land line comes into the house, and check to see what wires are used. Some countries use 2 wire systems others use 4
Feb 16, 2015 | Visonic Security Systems Visonic POWERMAX...
RESETTING A VISONIC ALARM
Line failure is related to power not phone line. What is the exact model number?
Nov 24, 2013 | Visonic INC Smarthome SecureLinc Wireless...
Programming vista 20p for 5882 receiver
Is this the only wireless zone you are adding to the system? Is the Vista20P programmed for other hard wired zones?
Feb 11, 2012 | Honeywell Vista 20P Alarm System Kit with...
6160 key pad "open circuit"
open ckt on the keypad refers to the data lines going to the keypad. check to make sure the yellow and green wires from keypad are properly connected.
Feb 17, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
Can I adjust the volume on my GE Networx NX-148E keypad?
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
Feb 10, 2011 | GE / Caddx Networx Programmable LCD Keypad...
Alarm trouble
OC means a wiring problem between the keypad and the alarm. Take the keypad and hook it up in the alarm cabinet and see if it works there.
Jan 22, 2008 | Cisco Alarm Expansion Panel (15454-AEP)...
Visonic INC Smarthome SecureLinc Wireless Home Security System SecureLinc Logo
124 people viewed this question
Top Visonic Home Security Experts
Gil Shultz
David Legender
David Legender
Are you a Visonic Home Security Expert? Answer questions, earn points and help others
