Question about OKI B4600 Printer
When I fill paper tray my oki b4600 printer says tray is empty. I have to remove 3/4 of paper for it to work.
vegakitten20
  • 685 Answers
SOURCE: need a servie repair manual for oki b4600 laser printer
if you go to there site you can get it there
Posted on Nov 10, 2008
SOURCE: printer message "paper empty custom in MP"
Its asking for you to put some paper in the tray at the side of the printer. There is a small hatch on the right hand side which will turn in to a paper tray when pulled open. Put in the paper and it will print. You will then have to disable that tray to prevent it happening again.
Posted on Dec 16, 2008
Buschchris1
  • 474 Answers
SOURCE: OKI B4600 Printer will not print = error - paused
Does it have a control panel or buttons on the printer itself?
If so, are any of them blinking or red?
Sometimes an error will cause a pause in the printer and you have to press one of the buttons to get it to start back up again.
http://my.okidata.com/PP-B4600-Black.nsf?opendatabase
This is the link to the manuf. website. I did a search on your model, theres a few so i guessed. but the manuals are available along with drivers.
I suggest you go and update them and go through the PDF and see if there is anything partaining to this issue.
I went through the PDF a bit and didnt see anything partaining to the PAUSE issue but try going through and see if anything is it.
On the printer icon on the bottom right of your task bar, right click on the printer icon and see if you can select CANCEL print job, then try unpausing it. Also, power off and then power back on and see if that clears it.
You may have to un-install the printer and re-install it and update the drivers to clear it.
Sometimes a Print job will get stuck in que when theres a jam or something and it wont continue till the issue is resolved, then you open and close the top cover and that resets it, it rechecks then continues.
Good luck.
Posted on Feb 04, 2009
SOURCE: oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Posted on Jul 09, 2009
SOURCE: How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Posted on Oct 07, 2009
Testimonial: "The one and only answer!!!!"
One of my employees use an Oki B4600. When she tries to print, it kicks the main tray out. This results in paper not being able to feed then it says paper jam (even though there is not an actual jam). Any...
Try to clean every rubber roller in the printer. Make some soft "paper" wet with vinniger (Juuice from grapes (not to drink but for in salad's)) and rub it over the rollers. So they can transport paper better.
If possible, removing the rollers, and then cleaning.
Ralf.
Dec 03, 2013 | OKI B4600 Printer
My paper feeds out the back and I want it to print out the front. How can I set this up?
If the paper output tray is pulled out at the bak then paper will exit through the back (face up). If you push this tray down then paper will exit out the top and lie face down on top of the printer. The tray that pulls out of the front of the printer is a input tray only and cannot be used to output any pages.
Jul 28, 2011 | OKI Electric Industry B4600 Laser Printer
PAPER FEEDS OUT OF THE BACK INSTEAD OF THE FRONT
If the paper output tray is pulled out at the back then paper will exit through the back (face up). If you push this tray down then paper will exit out the top and lie face down on top of the printer. The tray that pulls out of the front of the printer is a input tray only and cannot be used to output any pages.
Jul 26, 2011 | OKI Electric Industry B4600 Laser Printer
Paper jam
this is not a good printer.remove the paper tray and open the top cover.Remove the drum cartridge and remove any paper. you may also pull down the tray in the front of the printer and look for paper in there.
Dec 17, 2010 | OKI B4600 Printer
I have an Oki b4600. Any time I try and print It fails and says check paper tray. What can this mean?
It means check the papar tray ...
Do you have paper in the tray?
Do you have the right SIZE paper in the tray?
Is it inserted into the tray correctly? and is it all the way in?
Is there a jam in the paper tray?
Is the tray in the printer correctly? Is there a cover on the tray and it is in the proper position?
Thank you for your question. I hope my response is helpful to you. If it is helpful, the courtesy of a response and positive vote will be appreciated. Thank you.
Aug 16, 2010 | OKI B4600 Printer
Oct 07, 2009 | OKI B4600 Digital Mono Printer - Black
Oki B4600 ONLY prints to rear tray - how to print to front?
Yes. click on your printer icon. select properties then look for Tray or Output Tray or Tray settings and change it
Jul 08, 2009 | OKI B4600 Laser Printer
Oki b4600 drum reset ?
Jun 19, 2009 | OKI B4600 Printer
OKI B4600 Printer Logo
583 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
