Question about Philips 55PP9352 55" Projection Television
Phillips 55" rear projection HD ready --power button lights up, but no picture or sound--just a clicking noise. Also, we can no longer adjust the blue convergence. The adjustment screen comes up, but we can't align the points because the cursor won't move. We purchased the TV in 2002, and are wondering an approx cost for repair--or should we just replace?
Got our tv in 2004 and we're having the exact same problem. When the blue convergence started going a couple months ago my husband researched the heck out of it and decided it would cost less to just replace the tv with a newer, nicer model rather than repair it. And now, as of last night, we are having the same power issue where the power button goes on, but won't stay on. It just clicks on and off and no sound or picture. Did you ever get yours fixed, or did you end up replacing?
Posted on Dec 18, 2010
I have a Phillips projection tv. The picture looks curved and is crooked along the bottom of the screen. Red and green shadows appear around objects. Can you tell me what I need to do?
It sound as if you have convergeance errors.
To adjust the convergeance, follow the service manual's instructions as if you don't, the controls are interactive and it will be difficult to complete a reasonable adjustment.
Hope this helps.
Nov 19, 2010 | Philips 55PP9363 55" Rear Projection...
Our Phillips HD projection tv has lost a picture. It started by blacking out once in a while but now the picture is constantly rolling. The screen is distorted and it's impossible to even recognize what is...
Cloudy,distorted pictures.The tv have R,B,G CRT tubes gun coolant probblem.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced.
Sep 11, 2010 | Philips 55PW9363 55" Rear Projection...
55PW9363 55 in. Rear Projection HDTV-Ready Television: My Phillips big screen has double images and doubl...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 17, 2010 | Philips 55PW9363 55" Rear Projection...
I have a phillips 55pw9383/17f
Try going into your system menu under picture and adjust the convergence this will show a plus sign and you realign your picture I hope this helps
May 05, 2009 | Philips 55PW9363 55" Rear Projection...
Philips hd tv
possible mother board issues, alot of times they get very hot and will fry out. have you also tried the input button? they will sit on another input if a kid gets ahold of it or someone has changed it to play a video game or dvd.
Apr 25, 2009 | Philips 55PW9363 55" Rear Projection...
I have the 55" phillps rear projection tv
Common problem with this model. Goto www.TvRepairKits.com to get their chirping TV repair kit.
Feb 24, 2009 | Philips 55PW9363 55" Rear Projection...
Clicking noise
its the surge protector - plug it into the wall to see if that takes care of it and then put a UPS or uninterupted power supply on it so it has protection.
Feb 28, 2008 | Philips 55PW9363 55" Rear Projection...
No Picture or Sound
Hi! Kilrm,
Servicing this set can be difficult at best, and should be done by a qualified service tech.
Toprol
Nov 15, 2007 | Philips 55PW9363 55" Rear Projection...
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Philips 55PP9352 55" Projection Television Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
