Back to:
Tags:
Olevia LT37HV 37 in. HDTV-Ready LCD Television
Olevia 237-s12
posted by psycho-drive on Jun 02, 2008
Power light is on, but goes off when I try to turn set on and the T.V. will not go on and neither will the power light unless I unplug and replug it.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 14, 2008
FixYa! (100)
wyoed1
Rank:Guru Guru
Rating: 85%, 126 votes
It sounds like a bad power supply board. I have one in stock if you need one from a working set that has a broken screen. I'll send all boards for 100 dollars plus freight if you are interested. All boards include Power supply coard, tuner and internal lighting boards. Call me if your interested.
Ed
NC Electronics
307-266-4675
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Olevia 237-s12:
I don't want to Accept this solution
Can you Help with these Flat Panel Televisions problems?
Olevia LT37HV 37 in. HDTV-Ready LCD...
I have a TV Olevia LT37HVS and she does not allow me to...
What settings am I missing here? Is there a special...
I've recently purchased the 37" LCD. Everything...
Had a power outage and now the tv will not turn on. It's...
I hooked my progessive scan dvd player to the tv with the...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
