Question about Epson CX8400 All-In-One InkJet Printer
Instruction manual for Epson CX8400
I can't find my manual because I'm trying to figure out how to scan a newspaper article into my computer. Can this machine even do that?
I cant print from the computer to the printer (HELP !)
Posted on Apr 09, 2009
Go to support.epson.com and download the manual for your cx8400
Posted on Mar 02, 2009
  • 31 Answers
You can scan magazines and newspapers using this machine. You will need to use the Epson Scan software which is included in your printer driver disc. The picture below shows you need to select Home Mode and the important setting is for you to check the Descreening Filter option. You can just select other option to your own needs. For other question regarding this, please email me. Thanks!
Posted on Jun 04, 2008
Epson cx8400 stylus will not print from pc.it will copy and scan.dont know what happened
if you have the cd-rom
remove the program,reboot pc.
install the program back and wait whit connecting the cables,
untill the program ask for it.
Feb 02, 2014 | Epson Stylus CX8400 Series
How do I scan a document
Hi, You can download the manual with instructions from the following location: http://office.manualsonline.com/manuals/mfg/epson/cx8400.html
Regards, Icom1
Apr 04, 2011 | Epson CX8400 All-In-One InkJet Printer
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
My epson cx8400 is printing streaky, how do i fix this?
Print head likely needs cleaning. Read your manual for instruction on how to do this. Typically accomplished from the maintenance tab in your printing preferences.
Apr 01, 2010 | Epson CX8400 All-In-One InkJet Printer
How do I scan a picture using an epson cx8400 all in one printer
Open My Computer, double click on the scanner icon, follow the instructions of the scanner and camera wizard, don't use the printer buttons for that.
Nov 03, 2009 | Epson CX8400 All-In-One InkJet Printer
I have been trying to scan with my epson cx8400 went to self help but cannot seem to get the scanner/printer to work
To scan: Insert doc. onto the scanner then go to Start menu, all programs, epson scan, epson scan
Oct 15, 2009 | Epson CX8400 All-In-One InkJet Printer
How to Scan a Picture onto the Computer
<< In order for you to scan images or txt doc's from the scanner unit or all in one printers., You will an application to do that >>
> For Epson All in one printers you can use the application that came with the cd driver called
( Epson Scan ) or you can download it from the Epson Website.
try this link >> http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&oid=-10582&infoType=Overview
You need to select the model of your printer ( click on it ) < Drivers and Downloads >
choose your operating system and download the ( Twain Driver and Epson Scan Utility )
> If Epson Scan is already installed to your computer., Launch or open Epson Scan and on the upper
right corner of the window there are mode options you can choose from ( Home Mode., Professional Mode., etc ) you may want to use "Home Mode" its user friendly,
here's the link for the "user's guide" >> http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=90342&prodoid=63069506&category=Products
> If you have a windows system you might try using "MS PAINT" its a windows based application.
Click on Start / All Programs / Accessories., and look for "Paint" ( click on it )
on the Paint Window click on File and then click on From Scanner or Camera., just follow the step
by step instructions how to acquire / scan an image/doc's from your scanner. ( in some cases it will ask you which scanner to use if you have multiple imaging devices connected t your computer )
note :> if the "From Scanner or Camera" is graded out ( your scanner is not detected by your computer or it needs a twain driver to be recognized by your computer )
Jun 15, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson CX8400 All-In-One InkJet Printer Logo
377 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
