Question about Kenmore Refrigerators
I have a Kenmore side by side Model # 253.52622200, that is leaking water. It seems to be coming from the inside of the freezer side and running out onto the floor. Any suggestions??
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101...
Posted on Oct 17, 2010
Kenmore refrigerator model 363-58572892 side by side refridge/freezer. Water is appearing on floor in fron of freezer side. Appears to be coming from ice maker. Crack in cce mold? Clogged drain? filling...
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 29, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water Leaking from Freezer Side of Refrigerator
Got a couple of questions before we can really say much Does the refrigerator/freezer appear to be running as normal? is it perhaps always running at the time the water leaks for longer or more noisily than normal. Is the temperature of the freezer as normal? is there a particularly cold patch in the refrigerator , probably at the back or on the freezer side near the bottom? Where exactly is the water leaking from? and is there water collecting inside? Does the door seal properly at the base where the water seems to be coming from? Is there another major appliance with a heavy current draw that always goes on at the same sort of time? I'm thinking a water boiler, or aircon/heater, or the oven etc. Please post back, and we can start running through possible solutions :)
Jun 28, 2007 | Jenn-Air JCD2389G Side by Side...
I have Kenmore refregrator model 51272200. Water is leaking inside and forming ice at the bottom of the freezer. The refregrator compartment is warmer than usual. Your help on this is greately appreciated....
CK THE ICE MAKER WATER INLET TUBE IT MAY BE ICED AND CAUSING THE WATER TO RUN DOWN THE BACK / ALSO CK THE DRAIN IN BOTTOM OF FREEZER / A VERY COMMON PROBLEM . THIS WILL ICE THE BOTTOM OF FREEZER FLOOR AND RUN OUT ON FLOOR .. .. MM HOPE THIS HELPED ..
Jul 01, 2010 | Kenmore 53092 / 53094 Side by Side...
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
My Kenmore side by side refrigerator model 106.5686*601 is leaking water from the ice maker inside the freezer.
Icemaker leaks are common and cannot always be solved. May need a new Icemaker. Ofter you can obtain a kit from Lowes (use a Whirlpool kit.)
Aug 23, 2009 | Kenmore Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
My freezer is leaking inside the freezer area. I took off the panel on the inside and can see that it is leaking by the top of the coils. The water then freezes at the bottom of the freezer. Again all this...
This water comes from the defrost cycle. The drain hole is probably plugged with food. The drain usually goes to a small pan under the condenser where it eventually evaporates. Look for a hole or slot in the bottom of the unit.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
There is water leaking from the bottom of the fridge
Hi!!! It seems that your drain line in the freezer section is plugged remove the bottom tray and check for ice or water if you do the unplugg your drain line with a hair dryer..good luck..
Jan 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Refrigerator Ice Maker
it sounds like your inlet water valve is not closing all the way,pull frig out turn water off,remove valve get model number from inside the frig. and replace it,let me know-mike
Jul 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
154 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
