Question about Toshiba 36A50 36" TV
Vertical size of picture
The picture will be fine then a line starts flashing at the bottom the picture then the picture gets shorter vertically with a bright line at the center of the screen and some picture above that line
  • 4,234 Answers
You have a number of bad capacitors in the vertical circuit. If you can solder, you should be able to repair this yourself. I'll look up your model to get the parts needed.
Dan
Posted on Jun 03, 2008
Vertical line at edge of AV1 channel
hi! he might have adjusted the vertical hold and height including the linearity. normally on the board you would see a trimmer resistor with a label v-hold this is to stop the rolling, v- height for the size of the picture. and linearity for the evenness of the picture from top to bottom.
Aug 28, 2009 | Televison & Video
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
Picture broken and shrinking
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Nov 29, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony kv35s66: No picture, just sound and red blinking
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
Partial screen picture
bad caps in the vertical section
Dec 14, 2006 | Quasar SP-2722 27" TV
Toshiba 36A50 36" TV Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
