Question about Braun Shavers Male Pulsonic System 9595CC with LCD Screen Electric Shaver
Braun 760 cc. The cleaning fluid overflows when a new one is installed up to the point that half of it is gone. Then it still overflows a small amt. every time the razor is put back in after shaving.
SOURCE: Non cleaning razor
Dear Freddofrog,
please ensure you have removed the plastic plugs from the cleaning fluid container. If you have removed these i would suggest that the fluid contaner is faulty, your place of purchase should exchange this for you with no problem.
Posted on May 28, 2008
SOURCE: cleaning base
I have been shaving with electric razors for 48 years, and the Braun 8595 is by far the best one yet.
I have had the problem of the refusal of the cleaning station to recognize the level of fluid in the cartridge, three times over the last couple of years. It seems to relate to a build up of shavings in the unit. To get it working again I inverted the unit, and carefully flushed water via a small tube, back through the 1cm diameter hole in the underside of the open base. Of course, the unit must then be thoroughly dried before use, or the sparks may fly. Does anyone know how to dismantle the unit for a safer and more thorough clean?
Posted on Aug 09, 2008
clipperdoc
  • 17 Answers
SOURCE: Panasonic ES2206 elec razor vibrates but doesn't shave
if u had this for over a year and used it every day most likly the batties are gone, but u can try this, use the shaver until all the charge is gone complety wait 10 minutes charge the shaver for a full 24 hour without using it or unpluging it and see what happens some time u need to reset the battery for a full charge
Posted on Nov 14, 2009
SOURCE: My braun contour 5000 series razor leaks
Its no good
Posted on Dec 13, 2009
SOURCE: braun 8595 clean and renew
Perhaps the shaver's contact points are not contacting properly. I have this issue as well. Place the shaver in the cleaner-base as normal, then push the shaver in different directions gently then stop/hold for 2 seconds and see if the base then responds to the shaver ... if so then quick/dirty fix is to place a thin object, I use a tooth pick or dental flosser plastic thing and prop the shaver in the direction that works and it solved the problem. Otherwise, a new cleaner-station is needed (more than likely).
Posted on May 02, 2010
The cleaning unit on my braun series 3 (350 cc-4)shaver will not work although it will charge after buying a new charging lead? Any ideas?
These cleaning systems are prone to many problems. If the shaver will charge directly from the cord but not the stand, your stand is faulty. They are not repairable since parts are not available. A new stand can be found at shaveroutlet.com if needed
Braun Clean Charge Base 5783 Fits Types 5772 5774
May 07, 2017 | Braun Health & Beauty
Tip
Braun cleaning stand - pump will not run during cleaning cycle
My Braun shaver cleaning stand ran perfectly for several years until recently. The system would perform a cleaning cycle but I could tell something was awry because the shaver head didn't have the usual pleasant after-smell of the cleaning fluid. The blower motor inside the cleaning stand would run but the pump motor to spray the fluid into the cutter/foil assembly could not have been running.
WARNING - If your Braun Cleaning System and Shaver are under warranty, you will probably violate the warranty by pulling it apart for repairs.
I opened the cleaning stand (make sure you pop the upper section to allow removal of the cleaning fluid cartridge and let the system drain first! ) by prying the dome section from the bottom section at the circular gap around the body of the cleaning stand.
Once inside I inspected all the connections and located the pump motor. Using an external power supply (+12VDC) I confirmed the motor was either bad or locked down. (Remove the wires so that you do not subject the control pcb to the external supply voltage) While inspecting the bottom side of the pump section (this is where the fluid is drawn in) I noticed a white toothed gear inset into the white bottom section of the pump well.
I used a small screwdriver to rotate the gear to make sure the mechanics of the pump were not bound up. They were free and I tested the pump motor again. SUCCESS! The pump motor ran normally!
I then reassembled the cleaning stand and tested it with the shaver and Braun supply.
If I have more trouble, it is likely that the brush contacts of the pump motor are worn and when I rotated the pump gear, it placed the commutator in position to allow the motor to operate.
on Jan 18, 2009 | Braun Syncro 7526 Electric Shaver
Braun series 7 cleaning station has red lights even after I replaced the cleaning solution
When the razor is not regularly cleaned in the cleaning station and the hygiene indicator goes low, the cleaning station may lose its ability to sense the fluid level. I almost sent the cleaning station in for repair (mine is out of warranty) but was able to clear the faulty condition by resetting the razor's cutter replacement (holding the small recessed reset button below "Braun" logo on the razor) and unplugging/replugging the station then attempting a cleaning until it performed one completely successful cleaning cycle. After that the fluid level showed full. I also heard that the drain hole in the "cup" where the razor sits can get clogged - not sure what happens then but you want to keep that clean.
Update 2/2018: If you mix your own formula as others note, it is important to include some tap water for electrical conductivity for the fluid sensor to work.
Sep 15, 2013 | Braun 8585 Electric Shaver
I got a Braun Series 7 790 cc-4 shaver with Clean & Renew station from Amazon yesterday. All worked great trying it out last night. I left the shaver in the station, and last night I noticed the blue...
pit back in the charge station for at least 4 hours and switch the power on for the charger
many small battery chargers will flatten the battery if the power is switched off
if that fails , contact amazon for a return letter to get you warranty refund
Jun 05, 2017 | Braun Series 7 790 Pulsonic Shaver System...
Braun Clean and Renew not working
I took the file on a nail clipper and turned the impeller inside the unit. Remove the cleaning fluid from the unit. Turn the unit upside down, On the part that sticks into the large hole of the fluid reservoir you'll see the impeller. Just turn it it enough to dislodge any whiskers and try it again. Worked for me. Good luck
Jan 10, 2010 | Braun Health & Beauty
New door panel installation
try www.applianceart.com - not sure if they can help but may point you in the right direction
Apr 04, 2008 | Gaggenau GI936-760 Dishwasher
Cleaning solution .
I've heard of other people refilling the cleaning cartridge with other solutions rather than buying a new one. I understand the genuine article contains a lubricant as well as a solvent. You might have to manually lubricate the cutter head if you use a solution that does not include lubricant.
Dec 19, 2007 | Braun Syncro 7526 Electric Shaver
New cartridge-wont pump cleaner
The cleaning fluid "pump" is actually a small Mabuchi 6V DC motor that uses two small plastic spur gears in mesh to "pump" the fluid up a tube into the cleaning reservoir. Mine has died also and I cannot find a replacement motor. The cheapest I have found the base is here: http://www.electricshaverstore.com/get_item_scc1_braun-syncro-clean-charge.htm Good luck, Lynn Livingston
Jul 01, 2007 | Braun Syncro 7526 Electric Shaver
Braun Shavers Male Pulsonic System 9595CC with LCD Screen Electric Shaver Logo
295 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
