Computer freezing I put a new hard drive in my computer as well as a bigger RAM stick and power supply because my computer was shutting down for no reason. The shutting down has stopped now, but my computer will freeze all the time. I can Ctrl + alt + delete and shut something off (any old thing) and it will free up again for a little while until it freezes again. it will freeze while I'm using it or if I have my comp on and I walk away and leave it idle for a while, it will be frozen when I get back. I have nothing on my computer that was not there before the new hard drive and RAM. The freezing is so frusterating especially since I work on this computer for a living. It's not any specific name brand, since it was custom built, but my 2 hard drives are both seagates if that helps at all.
  • Jessica Edwards
    Jessica Edwards Jun 03, 2008
    I found it. I had a wireless mouse and keyboard. I still have the mouse, but the keyboard got a diet pepsi spilled on it. I got rid of the keyboard, but never unhooked the wireless reciever thing for the jkeyboard that hooked into the mouse port. I belive that was the problem, since I unhooked that thing, plugged in the mouse thing in the right hole and it hasnt froze up since. Its been several hours now. I know, I sound like such a guru with mouse holes and port thingies, but I know what I'm talking about anyway.. Lol ty for the help.
    Problem Solver:
  • 13 Answers
The shutting down as well as the freezing issue could have been caused by any one or all of the hardware you replaced.......the trick is to change one thing at a time to help narrow it down
Assuming the Ram/HD/PS are new and ok I would look at overheating problems.... is the computer dusty ...look at the Heatsink on the CPU is it clogged with dust and are all the fans working ......use an Air compressor or a can of air from a computer shop to blow the dust out....
Another reason could be a Virus or spyware/malware ....run a full Antivirus/Spyware check ........
Posted on Jun 03, 2008
  • Rasmick
    Rasmick Jun 03, 2008
    Excellent.......don't forget the above suggestions.... Antivirus/dusting....once a month or so are important
    Good luck
Dell e5520 freezing
Possibilities:
1. Dying power-supply is creating unstable voltages
2. Dying capacitors on motherboard are unable to stabilize voltages
3. bad RAM (compare to writing in pen on greasy paper -- nothing is realiably being recorded)
4. bad spots on disk-drive (computer is spending too much time trying to write to those "bad" spots)
5. other "dying" issues with the motherboard
Try:
1. different power supply
2. if you have more than one stick of RAM, remove one and test-drive. Repeat with the other stick(s).
3. Try different RAM.
4. Force CHKDSK ("Check Disk") utility to scan *all* of the disk-drive.
5 Inspect the motherboard for bulging/leaking capacitors.
6. Replace the motherboard.
7. Replace the whole computer.
May 27, 2014 | Dell Computers & Internet
How do you know when the power supply is failing?
Actually its not the matter with the Power Supply,but with the CPU Cabinet Power Button.I recommend that you should replace the Cabinet.It will surely help,and for the freezing problem it's your Hard Drive problem,you can also try re installing Windows...!!
But for the Power Button problem you should definitely replace the cabinet
Aug 21, 2012 | ASUS A7V400-MX Motherboard
Turned computer on and monitor instantly goes to sleep,also cant turn off the computer using button.have to use switch on power supply
Try this, unplug everything from the other board except the main hard drive, power connections, and monitor. if it does not come up, remove ram cards, leaving one stick. try again, if it is still bad swap ram sticks. If after all of this it still does not work you have a bad motherboard or processor
Nov 14, 2011 | HP Compaq Presario SR5210NX Desktop PC...
I have a Dell GX620 that I rescycled.It wouldn't power up so I put in a different power source and put in 1 - 512 stick of memory. It then started up and I reformatted the hard drive and re-installed...
just leave in one of the new 1gb stick of memory
if stable memory was the issue so add the back one at a time each time shut down install turn on test
if still unstable coould be the hard drive
May 29, 2011 | Dell OptiPlex GX620 PC Desktop
I have a Compaq Presario F700 and when I try to turn it on, the power light comes on for a second (I hear the fan), but then shuts off again. The cause is most likely that I was restarting my computer for...
Test or replace your PSU power supply unit preferably with a heavy duty one with plenty of wattage remembering that with any added hardware your computer will use more power/wattage eg:more RAM ,bigger hard drive,slave drive
One bad/faulty lead can cause a computer with lots of problems continually rebooting or failing to detect your drive
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps?
Nov 15, 2010 | Computers & Internet
I put a new power supply in, still get nothing but green light in back any ideas?
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you are the victim of a bad BIOS flash, don't freak there are some options. First off, if the computer (or motherboard) is still under warranty the Computer (or motherboard) can be sent to the Vendor for a BIOS reprogramming.
If you are a DIY PC builder and the warranty is expired you can take out the bios chip and sent it someone who reprograms BIOS chips or you can buy a brand new chip form them. I will show you my people.
http://myworld.ebay.com/***angelb***
or
http://stores.shop.ebay.com/Bios-Depot__W0QQ_armrsZ1
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen.
Jul 07, 2009 | ASUS M2N-E SLi Motherboard
Errore codeoxe0000227
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Could be bad ram, motherboard, cpu, powersupply, videocard.
Jul 06, 2009 | ASUS P5P800-MX Motherboard
Dell 4400 won't power up Flea light works
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
Jun 28, 2009 | Dell Dimension 4400 Power Supply ** FREE...
I have a HP M 7160 that will not turn on. There
Brian
Jun 20, 2009 | Bestec (ATX100-5) (ATX1005B) Power Supply
Computer won't start normaly
This is most likely do to a bad stick of RAM.
Try taking out all but one stick of ram and try booting. If it still doesn't boot try changing the stick out with another one you pulled (might be the stick you left in that is the problem)
In the case that it is bad RAM go to your local computer shop and get some new RAM for the computer or check if Gateway will replace the RAM.
If there is any display that comes on the monitor such as a 2 digit code try searching that or posting here with the code.
Jul 20, 2008 | Gateway GT5228 PC Desktop
Computers & Internet Logo
David Payne
David Payne
