Question about GE Profile Harmony DPGT750EC Electric Dryer
Smelled electrical burning last night and unplugged my GE profile dryer and one of the prongs(3 prong type) was burned
    President:
  • 1,430 Answers
This usually indicates a loose connection. Check the wire connection inside the outlet and the connections on the back of the dryer. Make sure the nuts are not cross threaded, this commonly happens with the fine thread. When a loose connection happens the electricity will generate heat trying to make the connection, the cause of many home fires every year.
Posted on Oct 15, 2010
Why doesn't the timer count down? The dryer runs & heats but the Timer doesn't move. I replaced the Timer block but nothing changed. Is this related to a bad sensor?
go bak to 4 prong. why did u change it out? souns lik this isa 220 unit and not a 110? chk the book that came with the unit. lol.
Jul 22, 2014 | Maytag Dryers
I suddenly smell burning rubber when dryer is on just moved it 3 days ago wired 3 pronged cord form a 4 prong wired live. ground. live. is something wrong and should i call the warrenty company???
Check the connections to make sure that you got them tight. They shoudl look like the ones in this tip...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
If everyting look akay there, then you should acll the warranty company becausethen you have other problems unrelated tot he moving...
heatman101
Apr 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Apr 23, 2009 | GE DVLR223 Dryers
JUST CHANGED MY GE DRYER TO A 4 PRONG PLUG, NOW NO HEAT
Sounds like your heating element is burned out (acually burned threw) when you moved it if the element was weak it may have broke in two along the coil wires.
Happens alot.
Feb 17, 2009 | GE Dryers
What type of power cord ( 3 or 4 prong) for an electric dryer
Hello markdraghi,
I assume ( but don't know) that you are replacing an existing dryer... That said, then you need to match the cord ( 3 prong or 4 prong) with what you currently have for a receptacle. A 3 prong uses two hot feeds ( red and black) and a Neutral ( white). A 4 prong uses the same as the 3 prong but also includes a Green wire for Ground. Get back to me if you need wiring details or if I have NOT answered your question. Hpe this helps.
Regards,
Rick
Jan 04, 2009 | GE DBSR453EBWW Electric Dryer
Burnt smell on dryer
Hello fyffeta,
3 or 4 prong power should have no bearing on the dryer performance..3 prong provides 2 power feed lines and a neutral versus a 4 prong system that provides the same two power feeds, a neutral and a ground.. so performance wise.. you should not expect any. The fact that it sounds louder is subjective and may be a function of the move. whereby something inside the dryer shifted a little when transporting it.. or the accoustics of the new room. If you smell something burning then I would check the exaust duct system for any material and/or restrictions.. It is possible that by moving your dryer..some lint, fibers from clothes or even human hair may have been dislodged and found there way into the blower/heater region and are burning off.. With the plug disconnected..Make sure your power cable terminations at the dryer are all snug. a loose connection there is dangerous and is resistive ( which means it will get hot) and in some cases.. could cause a fire so check that carefully..
In all probability..you may just have some lint or something that shifted during the move and is burning away...
Good Luck
Rick
Jan 03, 2009 | LG DLE5977 Stainless Steel Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
140 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
