Question about LG DLE2512W Electric Dryer
Own a DLE2512W/DLG2522W LG dryer. Display only showing CL and won't turn off even after instructions for child lock
4 Suggested Answers
  • 210 Answers
SOURCE: owners manual
The problem you are having is a vented related issue. Check your lint filter, run it under water and see if it pools on top. If so clean it. If not check your vent outside make sure it is not blocked.
You can go to the LG website and you should be able to download the manual there. http://ca.lgservice.com/index_b2c.jsp
Sgt 48
Posted on May 31, 2008
SOURCE: LG DLE2512W dryer approx 3 years old error message
I just had this problem with my 5 year old today. I unplugged it (after checking the line and the regular filter to make sure that they were clear). since there didn't appear to be a real problem. It works fine now. It wasn't having any problems before the light started flashing and it doesn't appear to be having any now. Hope this helps
Posted on May 22, 2010
MNTECH
  • 1543 Answers
SOURCE: cracked drum lg tromm dle2512w
I'd say yes, especially if you replace it yourself to avoid a service call. Top needs to come off (screws at back, then push top back 2 inches and lift off), remove front, remove 4 screws holding front bulk head / front rollers, slip belt off tension pulley, remove drum, reverse to install.
Posted on Sep 25, 2010
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
The check filter light keeps blinking and it displays CL in the display area. I always clean the filter after every load and I swept any remaining lint from the vent but it won't reset.
the filter light is just a reminder. it is not connected to a sensor or anything. it is not the issue. the 'CL' code is the issue. CL means that the Child Lock is on. press and hold the child lock button for 3-5 seconds to turn off the child lock.
Aug 22, 2015 | LG SteamDryer Series DLEX4070V 27...
Turned on Dryer today; problem; Estimated time remaining window shows CL (no time) Non of the time buttons selected show time in window. Dryer runs forever; gets hot and drys clothes. Pause button does...
The Child Lock feature is activated and it can be deactivated by pressing and holding the DRY LEVEL button for 3 seconds or until the CL display is cleared.
Indicate the exact model number of the dryer if the control panel doesn't look like the one shown above or if no button with the small "PRESS & HOLD 3 SEC TO SET CHILD LOCK" (DRY LEVEL) marking is found.
Mar 06, 2011 | LG DLE2514 Electric Dryer
The is a CL display on our dryer. What does it mean?
Hi
CL means you have activated the child lock or it may have activated after some buttons were pressed. Try holding down the temperature and eco/rapid options together to turn off child lock. If this doesn't work then unplug the washer for 5minutes and try again.
Hope this helps...
Daniel
Sep 02, 2010 | LG DLE2512W Electric Dryer
How do you turn off the child lock feature if CL is showing?
To unlock, press and hold DRY LEVEL for 3 seconds. The indicator light turns "off".
Aug 06, 2009 | LG DLE2512W Electric Dryer
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
Child lock setting
I had the same problem...called LG and they said just reset the dryer by unplugging the dryer....I couldn't reach the plug so they told me to trip the breaker switch and that would also reset it....problem solved
Feb 08, 2008 | LG DLE2512W Electric Dryer
LG DLE2512W Electric Dryer Logo
154 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
