Question about Whirlpool Dishwashers
Food remains on my dishes after a cycle. my dishes just won't get clean. I feel the water temp is hot. I'm thinking maybe I need to clean out the food trap (if there is such a thing) but I don't know how to begin. Please help.
  • 4,336 Answers
Well, this is kind of a big job. you need to disassemble all around the pump and clean screens. Also, clean discharge ports on the spray arms.
Really, dishwahsers do a poor job of removing food, and so plates should be pre rinsed.
Posted on Oct 15, 2010
LG dishwasher stinks since new model #LDF6920ST
list given is the wrong stuff to clean any dishwasher
LG LDF6920ST Dishwasher
thats an old dishwasher now
use recommended dish washer cleaners regularly
off the shelf deodoriser and sanitizes on an full empty cycle
check the filter at the bottom is kept clean each load clean
temp of wash water may no be enough
helps if you wash off any food stuffs on articals with hot water before placing in the dishwasher
Apr 06, 2017 | LG Dishwashers
The dishes just don't get clean. I know this isn't much to go on, but that's it.
Is the water hot? (make sure hot water is available to the machine at the start of the cycle by running the sink faucet until it is hot) Are you using the internal heater? (check the control panel for this feature) Are you using the entire cycle? (time) We are not talking about baked on food here are we? Dirty dishes that have dried?
Dishwashers cant remove baked on food no matter what the advertisement said. If the food is dried on, there is a better chance but ... dishwashers work best with freshly dirty dishes. If the food is dried, at least let them soak in the dishpan for a few minutes before you put them in.
How are you arranging the dishes, can the water reach all surfaces? (Think tempest in a teapot).
Have you tried other detergents? My preference is liquid though others may prefer granulated or tablet. I also like to use a product called Rinse-Aid.
If you have considered all these ideas and the dishes are still dirty ... there may be a mechanical fault with the machine. Is it making the proper noises?, Filling and emptying properly? (listen to it)
I hope you find these suggestions helpful ... Thanks for your visit today.
Jan 27, 2011 | Amana 24 in. ADB2500AW Built-in Dishwasher
Mould on inside of washer
The water may not be heating up. Does the DW feel warm to the touch when it is washing? How long do you leave dirty dishes in the machine? Do you empty the clean dishes right away. If you do not you should open the door a crack to allow the steam and moisture to escape so the dishwasher can dry itself.Some people who don't have a lot of dishes don't wash them often enough and this can happen. You should inspect the inside of the diswasher for food debris build up even in the little holes of the arms, which you can pull out with needle nose tweezers.You can't use bleach to clean it. Nor any other household cleaners.I would clean it with very hot water mixed in a little bucket with some dishwasher detergent. You don't want to introduce any other kind of detergent into it. I would clean it thoroughly, using a semi rough washcloth then use a clean cloth to rinse it off with hot clear water. Then I would run a full cycle with no dishes in it.Maybe even twice. I hope this is helpful!
Dec 16, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
Doesn't seem to wash the dishes. Maybe the wash
make sure the sprayarms are free from food deposits
and also spraying off food from dishes may help out check hot-water is on and heating element is working
Nov 25, 2009 | Dishwashers
Dirty dishes coming out of dishwasher dirty
check your drain line it should go up from bottom of d/w and then go down to drain that is so water from sink wont back up into d/w
Oct 27, 2009 | Dishwashers
Dishwasher leaving the remains of dish washing liquid all over dishes nothing is getting clean
Is water also standing in the bottom like it isn't getting pumped out? If so, probably the drain system is plugged and everything below the lower spray arm needs to disassembled to the deck--noting the position of each piece as they are removed. Look for food plugging holes in the deck and any obviously damaged parts. Clean the large screen in vinegar and hot water--let soak for a while to remove water and food deposits. Check the drain hose from end to end looking for kinks or other restrictions. Make sure the pump mechanism at the bottom turns freely. Check both spray arms for plugged spray holes or split seams. Reassemble in reverse order. Run a cycle without dishes to clean further--make sure the water drains out at the end. Listen for proper water movement while running. Open the door to inspect progress several times.
Aug 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Have bosch she45 that stays wet inside after cycle completes. some of the dishes are wet also, how do I stop this
First of all, Bosch is my Favorite! Secondly, maybe your heated dry button is not on. Are you keeping the door closed until the dishes have had a chance to completely dry? This unit has a system that drys with the walls of the d/w as long as the door remains closed. I hope this helps you. :>)!
Aug 14, 2009 | Dishwashers
I have a adb2200awb amana dishwasher which leaving glasses with a cloudy plus grid stuff on the glass and on the dishes. i use jet dry stuff plus the talbets with jet dry in them also i put them on a 2hr...
This is a classic sign of too much detergent. Are you only using one tablet? Too low of a washing temperature could also be your culprit. Dishwasher detergent needs to be washed with at least 120 degree water. Check to make sure your supply is hot (if it's plumbed to intersect with your faucet, just check faucet hot water supply temp). I'm not sure why you're running it on a two hour cycle, dishwashers can generally do the job in about 40 minutes. The grit is probably because there are food particles in your food trap. Make sure the food filter beneath the spray arm (if equipped) is clean and check the lowest areas for food scraps.
Jul 08, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
I have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho I do not think the water is spraying from the...
Welcome to fixya,
You said, you have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho you do not think the water is spraying from the arms with adequate force.
I have the same machine.
And I notice if I leave the dishes in the sink rather than rinsing them off and putting them directly into the dishwasher, (Like My Wife says to do). That sometimes I have the same problem.
So I bought Jet Dry, and filled the holder. It's a small sometimes clear plastic knob that unscrews out above the soap dish.Fill it once a month!
Do you put the detergent in both cups or only the closed one?
1. If the load is not real dirty you should only have to fill the one with the door that closes.
If it is real dirty then both. To always use both is a waste of money!
2. If your hot water heater is far from your dishwasher, let the hot water tap run a minute till it comes out hot, before starting the dishwasher.
3.If the dishes or pans are very dirty and or baked on use hi temp scower and heavy or potscruber for those loads.
I use heavy wash and hot temp scower if the stuff is relly messy or dryed on.
And for baked on HI- temp scower and pot scruber which sprays harder.
You will have to experiment a little to see what works for you.
You will find it washeing good after you find what works for your families dish habits!
If you have any more questions let me know!!!
Please remember to leave me a solved before you leave the site.
Thank You for using us!
Huuum
Oct 02, 2008 | Dishwashers
Dishwashers Logo
265 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
