Question about Kitchen Ranges
When you push the button to start the dryer, nothing happens. the heating elements light up, but the dryer will not turn on.
    Sergeant:
    Champion:
  • 226 Answers
There a door switch in the door jam that could be the problem but if not check the belt from the bottom depend on the type
Posted on Oct 15, 2010
Older Kenmore dryer model 86568110 wont start, i can see the heat element glowing but after pushing start button nothing happens.
Sounds like a broken belt. Do not continue to turn the dryer on until belt is replaced. With no air blowing over them, could overheat and cause a fire or burn them out.
Mar 17, 2013 | Dryers
Dryer will not start
It is very likely that the dryers heating element is burned out, that would be the 1st thing I'd test.
Nov 19, 2011 | Amana NED7200TW Electric Dryer
Hi. My Bosch WTL 5500 wont start. It has power and filters are clean. When you push start the dry light comes on and nothing happens. Any ideas?
there is a thermal reset button at the back of the unit on the heating element. to get to it you have to remove the back panel that covers the heating element. (its the panel that sticks out). Once that panel is removed you will see the red thermal reset button. press it so it clicks, then start unit. Let me know what happens.
Mar 18, 2011 | Dryers
I have a Kenmore 70 series. About 10 years old. The inside light comes one, the timer ticks when turned but nothing happens when I push the start button. We have already checked the breaker. Is there...
you either have a blown thermostat, blown thermal fuse, or a bad heating element most likely a blown thermostat
email me if you need more help in replacing or testing
Nov 16, 2010 | Kenmore 73952 Gas Dryer
Dryer will not start but light comes on, heats drum okay. The dryer heats, the light goes off when the door closes, checked the drum and the belt is okay. When the start button is pushed nothing happens.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 30, 2010 | KitchenAid KEYS750LQ Electric Dryer
Dryer heats up but won't turn
Depending on the make of dryer,there are several possibile reasons for this.
First and foremost, could be a faulty motor- faulty start capacitor, Faulty start relay.
Without more information I cannot be more specific.
Hope this helps.
Please leave feedback.
Thanks.
Nov 27, 2008 | Dryers
Dryer will not run
ck thermal fuse located on blower housing at rear should be white object with 2 blue wires ..if cks ok ck door switch
Sep 26, 2008 | Kenmore 63012 Electric Dryer
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Kitchen Ranges Logo
123 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
