Question about Whirlpool Washing Machines
Black grease spots on clothing.Is it possibly coming from under agitator cone?
  • 4,348 Answers
As bearings fail, this happens, presuming the grease was not on clothes in the first place. It takes special tools to repair this issue.
Posted on Oct 15, 2010
    Sergeant:
    Champion:
  • 226 Answers
Yes
Leaving black residue (spots) on clothing
Black spots usually come from the agitator shaft bearing seal which will, when worn, allow oil from the transmission to seep into the wash. Replace the seal, and maybe the upper bearing if the shaft itself will move visibly from side to side in various directions. If the machine is still under warranty, take advantage. Hope this helps!
Apr 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Seems to bee grease getting in from sum where as
Take off the agitator and look for signs of oil coming from under collar that supports the agitator.
If so it means that the seal has gone and water has got into the transmission forcing the lubrication oil to be pushed up through the seal.
Big job to repair.Sorry
Feb 23, 2010 | Westinghouse WWS833ES Super Capacity Top...
GE WHDSR209D2WW has black grease in the wash water
The grease comes from the transmission. Part 320 on this diagram. You can see from the price it may be better to but a new washer.
depends on weather or not you can do it yourself.
Feb 11, 2010 | GE Profile Prodigy WPSE4200A
ON the second wash I did today, after the second wash my clothes came out with streaks of black. What would cause this?
Grease is leaking into the drum under the agitator cone.
Remove the agitator cone. There will likely be a removable plastic piece with an O-ring. Oil could be leaking out of the O-ring into the washer, and water could be leaking into the bearings. If there is damage to the O-ring replace it, or if there is a bunch of schmag that is compromising the seal, clean it out, and re-install everything. This solved the problem in my washer; hopefully it works for you.
Sep 29, 2009 | Kenmore Washing Machines
Grease leaking into drum under agitator cone
Sep 28, 2009 | GE Washing Machines
Stains on clothes
yeah if the seal has gone even slightly then it will send grease out 1 way to check if the bearings are on there way out is pull the washer out take the back panel off and look in to see if there are any green spots on the back off the washer if there is then there on there way out another way is to place your palm on the front of washer place your fingers into the drum and pull your fingers up if there is movement then there going m8
Feb 09, 2008 | Washing Machines
SPOTS ON WHITE CLOTHES
if your washer has a slight rumble noise when on the spin then it is most likely that your bearings are on there way out,what it is is the bearings have grease in them and once the bearings start to go this grease starts to leak into the drum which is what the brown spots are it also leaks at the back around the bearing at the back of your outer drum and also leaks onto the floor this will need fixing by a domestic appliance engineer but it is sometimes cheaper to replace the washing machine
Oct 17, 2007 | Washing Machines
Washing Machines Logo
242 people viewed this question
Dan Webster
Dan Webster
Sal De
