Home | Danby | DDR583R Dehumidifier | DDR583R Danby Deh...
Danby DDR583R Dehumidifier
Problem for Danby DDR583R Dehumidifier
DDR583R Danby Dehumidifier
By llallen on Jun 02, 2008
Hi
Thw water is now staying in the machine instead of going into the front that I have been emptying. I can't locate the manual to make sure I have it set up properly.
Do you know what settings I should have it on. My brother in law moved it and I'm not sure if he may have touched something as it had been working great until then.
thanks DDR583R the water does not go into the front bucket, but stay inside of the Unit and leaks all over the floor. I do not want to use the direct drain feature and don't know how to turn this feature off if this is what is happening.
Same Problem
Dec 06, 2008
-   I have the same problem. Unit works well for about a month, then little water in the bucket, but lots of water on the floor. I've taken the panels off and cleaned everything I could reach. It works well again for about a month, then the same problem occurs.-   Bamboozled
Jun 28, 2008
-   Mine does not drain into the front bucket, but leaks onto the floor. -   lserv60
Solution #1
posted on Aug 11, 2008
Somewhat Helpful)
yves22
Rank: Apprentice
Rating: 70%, 1 votes
Was this helpful?
Yes
No
Solution #2
posted on Jul 26, 2008
Very Helpful)
R00kie
Rank: Apprentice
Rating: 100%, 3 votes
Use a piece of ethernet cable and carefully push it through the water discharge area's...This should free up the grime that's clogging the drainage holes.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Danby DDR583R Dehumidifier
Questions and Unsolved Problems for Danby DDR583R Dehumidifier
Do you recommend Danby DDR583R Dehumidifier?
Answer
Answer
After a lengthy period of inactivity, we came to use the dehumidifier and noticed that the LED... (More)
Answer
I have been emptying the tank few times a day, because I had no convenient drain in basement. Now, I... (More)
Answer
Model DDR6588EE - called Danby and they will not tell me what part I need or how I can order it due... (More)
Answer
My unit is collecting moisture VERY WELL! BUT it blows warm air only which makes it very hot in our... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DDR583R Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
