Question about Toshiba PDR-3300 Digital Camera
I need a SD card and would like to know if there are any compatable SD cards fot the Toshiba PDR-3300. Thank you.
  • chewprin Oct 15, 2010
    I tried a 2 GB SanDisk Card and a Kodak 4GB SDHC.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Toshiba Master
  • 102,366 Answers
Any SD card will work. You don't need to specify a particular brand, and speed won't make any difference to the camera (though a faster card may speed up downloads via a card reader). Just make sure you get an SD card, not an SDHC card.
Posted on Oct 15, 2010
  • 1 more comment
    I tried other SD cards and they don't work.
  • kakima Oct 15, 2010
    Ah, that's totally different. What size(s) are they? If any of them are larger than 2GB then they're actually SDHC cards.
    What happens when you try to format any card 2GB or smaller?
    And what happens when you try to format the 2GB card?
When i put my sd card in my camera wont turn on
The PDR-3300 works with MMC and SD cards. Your new 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the camera. You need to use SD cards, 2GB and smaller.
May 13, 2012 | Toshiba PDR-3300 Digital Camera
2gb sd card wont format this is a toshiba pdr-3300
Hi, is it an SD card of normal size? if so there's a little switch on the side which says protect, move this the other way to enable Formatting..
Thanks Mark
May 03, 2010 | Toshiba PDR-3300 Digital Camera
Lost memory card
Why can't you use a different card? Just put it in and format the new card in the camera.
Rob
Mar 11, 2009 | Toshiba PDR-3330 Digital Camera
Missing memory card
In all probability the memory card that came with your PDR-3300 was:
SD 8 MB Toshiba Memory Card.
SD cards with a much larger MB can be obtained at any large Drug Store, i.e. Walgreens, CVS, etc.
At the present time, these cards, 32 MB and larger are very inexpensive.
Feb 18, 2009 | Toshiba PDR-3300 Digital Camera
Memory card locked
pull the SD card from the the slot and it right side up with the label facing you, there is a short slot on the side with a sliding switch. move it to the other side of the slot and that will unlock the card. (it probably go moved as your were putting the card back into your camera) good luck!
Jan 11, 2009 | Toshiba PDR-3300 Digital Camera
PNY 2GB memory card
I have the same camera and bought a 4GB PNY SD card and it wouldn't work, so I read the manual :) The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
8MB, 16MB, 32MB, 64MB, 128MB, and 256MB"
Hope this helps! -Kim
Jul 15, 2008 | Toshiba PDR-3330 Digital Camera
Problem with camera writing to memory card
try this first: pull the SD card from the the slot and hold it right side up with the label facing you, there is a short slot on the side with a sliding switch. move it to the other side of the slot and that will unlock the card. (it probably go moved as your were putting the card back into your camera) good luck!
Jun 23, 2008 | Toshiba PDR-3300 Digital Camera
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Card Error Message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. The Toshiba PDR-3310 is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. The PDR-3310 may work with some MultiMedia Cards, but is not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Toshiba PDR-3300 Digital Camera Logo
62 people viewed this question
Top Toshiba Cameras Experts
john milligan
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
