Question about Kenmore Sewing Machines
My machine is old and has been super reliable. i clean it fairly regularly. for the past few days it labours and doesn't seem to get a "grip", like it howls and any fabric is too heavy for it to go through, now it stopped altogether.
  • isidora403 Oct 15, 2010
    yup, I guess you must be right and - yes I have also greased it, regularly but there is also a faint smell so ... thanks.
    President:
  • 2,047 Answers
Machines are such that they need grease ic certain areas. When they dont get grease in these areas they tend to still work but they do so with so much strain. One of such places is the main needle head which is the mechanism that drives the needle movement.
Cleaning the machine is usually not enough the machine has to go for servicing on a regular basis. For example when the machine started working laboriously is should have been sent for servicing.
First check if there is anything smelling burnt inside the machine if there is then a prt or two has to be replaced, but if on the other hand nothing smells burnt then the machine would need simply to be serviced. Get an expert to examine it as no correct diagniosis can be given without proper examination of the machine.
Hope this solution has been helpful?
Posted on Oct 15, 2010
  • Rockme
    Rockme Oct 15, 2010
    Thanks for the feed back.please do ensure to rate the solution provided
Why r all my stitches super small
Most likely the stitch length is set to a very small stitch. The higher the number, the longer the stitch. If not that, then the feed dogs are not advancing as they should. If it is an older mechanical machine, something like this often happens because the machine has not been thoroughly cleaned and oiled regularly. The old oil dries up and restricts the moving parts.
Dec 19, 2016 | Sewing Machines
My Activa 130 makes a clacking sound when I sew. It is 10 years old. What do you think is wrong? Can I repair this or do I need to take it to be serviced?
I would take it to a Bernina repairman, nice machine and well worth getting it serviced by a qualified technician.
I presume that you've tried the obvious things like a new needle and checking the bobbin case is in correctly.
Sep 03, 2011 | Bernina Activa 130
Hi, I'm missing a bobbin case on my Singer 2517, where can I buy them ? Thank you.
Go to www.sewingpartsonline.com and you can order one for $11.99. This is a great spot for finding old parts. There are others but I have had good success with these people, fair prices and reliable.
Oct 28, 2010 | Singer 2517 Mechanical Sewing Machine
I've been doing a lot of sewing over the past week and now the bobbin area sounds really noisy -like metal rubbing. The stitching is fine it sounds terrible. Do I need to oil the machine, and if so, where...
Hi. Your machine is probably just dirty. Have you cleaned out the lint? It will build up in the bobbin area and cause all kinds of problems unless you clean it out. A small brush works wonders. Take out the bobbin and bobbin case and clean all that old lint out. At the same time you clean the machine, you should also oil it. Use regular sewing machine oil and put one drop in all the oil ports (see my photo of an oil port at robbiesews.blogspot.com). If you don't see the oil port, the old rule of thumb was one drop of oil wherever a metal part rubs against another metal part.
I clean and oil my machines after every 8 hours of sewing and I think that's pretty much what the manufacturers recommend, although some new machines are self-oiling. Check your manual to be sure. (Self-oiling machines still need the lint cleaned out regularly.)\
Hope this helps!
Apr 05, 2010 | Riccar Sewing Machines
Machine does not feed properly. It sewed fine for
Here are a few solutions to check.
* Check your fabric to make sure it isn't caught on something.
* Check your pressure foot to make sure it's screwed tightly in place.
* Adjust the pressure of your pressure foot as it may be too light or too heavy for your fabric.
* Check your feed dogs for lint. If your feed dogs are clogged with lint, they're not gripping your fabric properly. Remove your pressure foot and clean out any lint with an old toothbrush.
* Raise your feed dogs if your machine has this function. They may have been inadvertently lowered.
* Check your stitch length regulator, If its set at “0” or a very small number, try switching to a longer stitch length.
* Change your needle, it may be damaged.
* Check your needle plate and make sure it's securely in place.
* Use a “Jean-a-ma-jig” or a “Hump-jumper”. If you've been trying to sew over a bump of fabric, such as a thick jean hem, try using this tool (your local fabric store should carry it). It keeps your pressure foot level as you sew over the bump and gives your feed dogs something to grip.
I hope this helps
Mar 13, 2010 | New Home L-372 Mechanical Sewing Machine
I have a old old elna Stella 27 and it's a beauty but I am having problems with the lower thread tangling until it is a thickish mass around the outer side of the place the bobbin goes, but then sometimes...
Hi! Congratulations on your old Elna! I just love old sewing machines; they are so solid and reliable.
(Unless of course you're getting a big bird's nest with the bobbin thread, right? That's so frustrating!)
With my old machines, I've found that a tiny bit of thread caught in the bobbin assembly can cause these nasty tangles. I use a bright flashlight and a pair of tweezers and just keep looking until I find it. While you're in there, clean out any old lint or gunk (meaning, old oil) you find. Brush all the lint out. I use a q-tip moistened with a bit of WD-40 to clean the gunk (but be careful that the fuzz from the q-tip doesn't come off while you're cleaning). With the WD-40, you have to be very careful not to get any of it on the surface of the machine--it can mess up some of those beautiful old finishes.
So clean the bobbin area, make sure you're threading the bobbin correctly, and lastly, if you hold the tails of the top and bobbin threads snugly in your left hand behind the needle while you take the first few stitches, the birds' nests should be a thing of the past.
Let me know if this works, ok?
Happy Sewing!
Feb 10, 2010 | Elna 2007 Mechanical Sewing Machine
Designer 1 touch screen freezes
You probably have the old-style touch panel which is known to fail. Viking has a five year warranty on electronics but sometimes they will cover this particular part beyond the five years. If you find a sympathetic dealer you may be able to get the part for free. You will need to pay for the labor though.
Feb 05, 2009 | Husqvarna Designer I
Advice
Not sure which machine you are referencing but if is the 16231...it is highly recommended. There is literally no issues with this machine reported in the past 2 years it has been out.
CAN NOT GO WRONG! More than worth the $$ You will be please with the reliability of a mechanical machine with the benefit of a few "can't live with out" electronic features, up/down needle button. start/stop button, speed control lever! It pretty great. You can also go to sear.com and read soem other reviews form customers. It comes pretty highly rated.
Nov 06, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
I have a very old viking - feed dog problem
The older 6XXX series are the best machines Viking ever made. But they have one flaw - if the button hole mechanism is not regularly serviced and used, it will eventually stick and the machine will only sew in reverse. This can also happen if you turn the knob backwards when in button hole mode.
I always tell my customers to make a few button holes every time they use the machine. This helps to keep the mechanism free and working between servicing.
Unfortunately the fix is not a DIY consumer project. It requires knowledge and expertise in disassembling the machine and re-aligning the parts. Expect to pay anywhere from $25 to $75 in addition to the regular servicing fee.
Steve P
Minneapolis
aka "The Bobbin Doctor"
Oct 05, 2008 | Husqvarna Viking 1
Sewing Machines Logo
201 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
