Question about Stoves 720EF Electric Double Oven
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't remember how to rectify. Help appreciated! Best regards, Geoff.
  • Stoves Master
  • 3,463 Answers
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
Posted on Oct 15, 2010
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
Jun 28, 2011 | Stoves 720EF Electric Double Oven
Clock keeps flashing i keep setting clock but after 5 minutes or so starts flashing again putting tape over ready time button to hold it down then reset clock seems to work till the tape comes loose Stove...
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Nov 14, 2010 | Stoves 720EF Electric Double Oven
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
How can I bypass the clock on my Stoves Heritage 720 ef oven?
I think you will find that the clock/timer is an integral part of the oven and so if it is faulty or missing, the oven will not work. Because it controls so many things, I would say it would be easier to buy a new clock.
Jul 08, 2010 | Stoves 720EF Electric Double Oven
Hi, I have an oven ''Stove 605 MF'' and we had a power cut but for some reasons when the power came back the oven lights started blinking constantly and we are unable to use the oven since then??? I tried...
Try holding the cancel/off button for 10 seconds.
If that does not correct the problem you probably have a bad clock control from the power surge when power was restored.
Mar 20, 2009 | Stoves Ovens
Problem with electric single oven Tecnik tkc241/2
Hi, switch off the mains for the cooker, wait for about 15 seconds, switch it on (0:00 flashing) then press the 2 buttons on the left at the same time and hold them, and then press the - or + button to set the time.
Cheers
Feb 19, 2009 | Tecnik TKC215/3 Electric Single Oven
Oven comes on of it's own accord following power failure
no you are not over reacting that could have burnt your house down I would demand a new one sometimes you just got to be pure hateful with these manufacturers and tell them you going to give bad ratings all over the net hope you get somewhere with them Please give high rating
Jan 05, 2009 | Ovens
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
Stoves 720EF Electric Double Oven Logo
601 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
