Question about Juki DDL-8700
Hello-- I am sewing on an industrial machine (Juki DDL 8700). it has worked well in the past but currently it breaks its needle before it stitches even 2 inches. i replaced the throat plate and the needle, it looks like they line up properly. i sew very heavy stuff and i do nick up the throat plate eventually- but this is being caused by something else. thanks, jenae
    Scholar:
  • Juki Expert
  • 176 Answers
Hi there
firist make sure you are use throat plat with big hole if you are use big needle size like 18# or 21#?
second check timming between needle and hook ok or no ?
thired check the blade point of hook toutch needle strong or just light touch?
finally which model you are used? DDL8700-A or DDL8700-H?
best regards
ashraf abozid
aabozid@hotmail.com
Posted on Oct 30, 2010
Testimonial: "i had solved the problem but these are the right steps to take. thanks. jenae"
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
Needle breaking
The most common problems that cause broken needles is a thread tension that is too tight and the machine needle/hook being out of time.
Nov 25, 2015 | Juki DDL-8700 Industrial Straight Stitch...
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Hi, i've an error on my Juki DDL-8700-7 trhat read Err-11.
Dear Maciej
good day to you
regarding error E11 please see attached photo.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Oct 06, 2014 | Juki DDL-8700-7 Industrial Straight Stitch...
My juki 8700 h frays thread while trying to sew
Hello Daniel, I suggest you start with a new needle. Back off the needle thread tension and the bobbin thread tension to a minimum and see how it sews. If it does not ravel the thread, you can increase the tensions until you acquire the stitch you want.
Mar 26, 2014 | Juki DDL-8700 Industrial Straight Stitch...
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
Obtain Juki Industrial User's Manual 8700-7
hi there
u can find at www.juki.com under industerial sewing machine
u can download DDL 8700-7 instruction manual
best regardes
ashraf abozid
aabozid@hotmail.com
May 23, 2010 | Juki DDL-8700
Juki DDL-8700 Logo
223 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
