Question about Kenmore Kitchen Ranges
I have a Kenmore Range 95802000 and when I go to self clean it gives me an error E1 F5 .. What do I do.. IT wont lock or start cleaning. Thanks - Toni
    President:
  • 1,430 Answers
2. If door not latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Check the door switch and latch switch for continuity as described. If you need diagrams or illustrations of your specific model try this link
Replacing oven ERC
There is also a link to show you how to use a multi meter
Posted on Oct 15, 2010
  • rpaint01 Nov 13, 2010
    I have a Kenmore 95115102 and all I did was manually cycle the door latch a few times. It's at the top of the chassis when the door is open.
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Aug 28, 2010 | Kenmore 92002 / 92004 Kitchen Range
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I tried to set my self-cleaning on my Electric Kenmore range model # 66592012100 and I get the error message E1 F5 I can't set my oven to self-clean just my luck
May 13, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
I have a Kenmore self cleaning electric range # 95014. When I try to start the cleaning feature it seems as if it is going to start then it beeps and E1 F5 comes on. What do I need to do.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.DGF$^%&*
Feb 25, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
Self Cleaning won't work
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%TY
Feb 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
E1 F5 error message when try to activate the self clean
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
KEMORE OVEN SELF CLEANING
Aug 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven locked after celf cleaning
Aug 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Kitchen Ranges Logo
147 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
