Question about Philips Televison & Video
I plug my tv up and it won't come on. But when I unplug it it makes a sound like its being cut off.
    Top Expert:
  • Philips Master
  • 75,169 Answers
This is a special symptom usually occurs with philips TVs. There is some sort of short inside your TV. It may be due to some circuit componets failure. Philips power supply systems are so designed that if any kind of short occurs inside the circuit board, the TV won't switch on. It is a protection. At the time you plug in the tv to AC the SMPS inside the TV works, detects a short and shuts down. When you switch off the set, the stored power inside the filter capacitor will be discharged through the power circuits, and a "WIZ" sound will hear. We can't predict the exact point of short in this case. It must be checked out correctly with patience. Anyway, without rectifying the short, your TV won't switch on. Please contact a service personal. Do not put it to on and off again. It may make the things more worse.
Posted on Oct 15, 2010
Internal speakers won't turn off when external audio is connected
Normally , you would expect the TV sound to stop when headphones are plugged in. Obviously not in this case. If you have a set of headphones, try them and see if the TV still has speakers on. If it does, then there may be a setting on the setup of the TV to get headphones to work. If the TV speakers stop, then I would think that the Logitech are not compatible with the TV. The only other thing would be is to get into the TV and disconnect the TV,s own speakers. If the wires are soldered on and not terminal connected, carefully cut 1 of the wires off near the speaker. If 1 wire is cut, the speaker wont work. Make sure both the TV and the additional speakers (If they have their own power supply) you are using are unplugged from the power before you go doing this...!
May 26, 2015 | Haier L32F1120 32-Inch LCD TV 720p 32"
Technika 40-270 lost it's sound
Check the sound menu and set "Digital Output" to "Auto". Also check to make sure nothing is plugged into the headphone jack as this will cut off the internal speakers.
Try resetting the TV by unplugging it for five minutes.
Still no sound, you will have to take it in for service or contact Technika if under warranty.
Jan 05, 2015 | Televison & Video
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
My tv keeps saying stand bye and it won't cut on all its doing is making the click noise and the red light keep blinking
Try unplugging it for 30 seconds and see if it resets. If not, take the model # and get on the internet for the manual and go to trouble shooting page. It should answer your questions
Feb 13, 2013 | Televison & Video
Sony blinking codes
If i remember correctly ten blinks means a high voltage error.
The only thing you could try is unplugging the power cord then plug it back in and try turning on the tv. If it still won't turn on try unplugging the power cord for five hours or longer and try again. If it still won't turn on it would be best to find a local repair shop that works on sony tv's and have them repair it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-51WS550 51" Rear...
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I've had several power cuts lately , now my tv is
Hello rogerstanila,
if you have tried unplugging it for a while and if there is still no change then it could be your main board. Unfortunately to fix this could be costly. See if you can find a repair tech that will do a diagnosis for free. But there has quite a bit of problem LG tv's being stuck on standby especially the LCD tv's, Other than this there is not much you can, maybe changing the battery of the remote and just keep trying to click on and off. If it is plugged into a cable box, try unplugging all of that for a while. Leaving it unplugged for a day won't hurt. If nothing else then it could be your main board. You could replace it but as I said before it could you couple hundred dollars. Hope this some what helps.
-Joe
Aug 30, 2011 | LG Televison & Video
TV has no sound
Just a thought...does the set have a headphone jack? When you plug in most headphone jacks it disables the internal speakers. If it does have a headphone jack trying plugging in some headphones to see if you have sound there. If you do, plug/unplug it a few times...worth a shot.
Nov 18, 2007 | Philips 25PS40S 25" TV
No picture but has sound
hello .this does sound like bad solder joints .all printed circuit boards do this after a while due to heating and cooling .is not advisable to try to repair yourself .possible electric shock and spiking .will do a lot of damage .take to a shop to have repaired
Oct 30, 2007 | Sony KV-36XBR450 36" TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
