Makita 193737-7 BH2420 24-Volt 2.0 Amp Hour NiMH Slide Style Battery Logo
Posted on Oct 15, 2010
Battery dead but the charger says its fully charged
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Battery will not fully charge. is replacement battery available?
You need a new battery if your alternator is putting out 14.5 volts you can try a charger just make sure you disconnect both cables and try a charge of a charger if it still doesn't take you most likely have a dead cell which may as well be a dead no good battery
Battery charger reads battery full when dead
The battery is no longer good. You will need to buy a new battery. Don't over charge your batteries. They all vary. Expensive cordless tools will come with a charger that shuts off automatic to prevent over charging. I own cheap Skill drills that has served me well. These batteries lasted over 11years. It makes no sense. They should not have lasted more than 5 yrs., even 2yrs. I make sure I never over charged them, but they should not last that long. Freaky. Your battery is dead forever, sorry. I have others just like yours waiting to be recycled.
Jeep is completely dead but battery is fully charged
have your alternator tested, and check all your fuses
2helpful
Included in my Ryobi printed instructions are the statements: 1-"Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode. 2-"To obtain the longest...
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
8helpful
How do you read the gauge. Is 100 fully charged or is it empty?
The gauge reads the amps that the charger is putting out. So 100 would mean the battery is dead and 0 means it's fully charged.
Battery in Jeep Grand Cherokee dead this am and less than 1 year old. I have a Everstart 100 battery charger plugged in and on the car. How long does it take to charge the battery. The charger is plugged...
How many amps does this charger put out????
A small trickle charger will take forever to fully recharge a dead battery, you'll need to have a battery charger that can put out enough amps to properly charge a dead battery.To clarify, the chargers sold at Sears, the large square types on wheels are the best for charging dead batteries and they also have an amp meter telling you how much the battery is accepting. After you charge your battery, you should be around 12.5 volts to 12.7 volts. DO NOT OVER CHARGE!!!
1helpful
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 • Drills
1helpful
My battery charger shows (green) fully charged when it is dead
THis is really a sign of a bad battery that is always being detected fully charge but its really drian , so it will be better for you to replace that battery.....
My battery went dead this morning i charged it this evening and it is just showing a battery and timer wont switch on or charge??
from what I hear, you have either fully charged your battery or your battery is pretty much completely dead.
your options:
1. If it's completely dead and won't hold a charge it's time to purchase another battery, this happens from time to time so don't freak out about it.
2. If it's fully charged, try taking the battery completely out of the phone, and re-inserting it after a few minutes, sometimes cell phones need to be reset.
3. ensure that your charger is working properly, if its not getting juice to it neither is your phone.
4. try to dial your number just to see what happens to the phone.
5. if someone else u know has a charger like yours try to borrow theirs to charge your phone possibly ruling out a bad charger
Top Makita Air Tools & Compressors Experts
vince
john h
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
