Question about RCA CC6383 VHS-C Analog Camcorder
Camera displays error code "E03 REMOVE AND REATTACH BATTERY UNIT IN SAFEGUARD MODE"
SOURCE: Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Posted on Mar 21, 2007
cvslkjsdflkds
Posted on Jun 15, 2009
57 varieties
  • 1653 Answers
SOURCE: Error E03. Unit in safeguard.Mode remove and
Make sure there is no tape jammed in the mechanism anywhere and carefully clean around the whole tape compartment with cotton buds and isopropyl alcohol to remove any dust and debris, particularly on the opto sensors for read/write and tape present. If this does not solve the problem, try a different tape and if it does not solve the problem then you will need to get it serviced. This is a real pain problem in JVC's and Panasonics and servicing (which may be costly) or scrapping is the only resolution.
Posted on Oct 06, 2009
57 varieties
  • 1653 Answers
SOURCE: E03 safegaurd mode remove and replace battery? how
Make sure there is no tape jammed in the mechanism anywhere and carefully clean around the whole tape compartment with cotton buds and isopropyl alcohol to remove any dust and debris, particularly on the opto sensors for read/write and tape present. If this does not solve the problem, try a different tape and if it does not solve the problem then you will need to get it serviced. This is a real pain problem in JVC’s and Panasonics and servicing (which may be costly) or scrapping is the only resolution.
  • 4 Answers
SOURCE: JVC safeguard
I MADE MINE WORK!!!! With the camera off, I pressed and held the "play" button while I powered it on into playback mode. It actually let me watch the tape. I switched it to "REC" mode and still got the error. So I switched it off, pushed and held the rec button while powering it on... IT WORKED. Now I can power it on and off with no more error messages (so far)! Let me know if this works for you too!
Posted on Dec 12, 2009
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
SAFEGUARD MODE ERROR CODE E06
Why not do what the manual says ? They're printed to assist you.
Jul 14, 2017 | JVC GR-D201U Mini DV Digital Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Error Code
remove and reattach the battery
Sep 29, 2007 | Video Cameras
Mar 19, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
RCA CC6383 VHS-C Analog Camcorder Logo
37 people viewed this question
Top RCA Video Cameras Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
ray gallant
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
