Question about Hotpoint 22 in. 7892 Built-in Dishwasher
Water does not completely drain from unit - Hotpoint 22 in. 7892 Built-in Dishwasher
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Oct 16, 2010
My water isnt draining after the cycle is completed.
Hello & Welcome to FixYa
As the water did not drain completely then check the drain hose & drain pump filter for any clogs/obstructions, if you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 17, 2011 | Whirlpool GU1200XTLS Stainless Steel...
Mah7500aww
what it sounds like is the drain from your house wher the washing machine drain hose hooks into is daraining slow so after it spins and pumps the water out the pump shuts off but the drain hose is syphoning the water back into the machine,theres probally lint built up in your drain pipe
Jul 09, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
Feb 03, 2011 | Kenmore Washing Machines
After wash complete unit will not drain complete, water remains in filter trap. this water will smell after a short time.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
heatman101
Sep 06, 2010 | Bosch Dishwashers
Fujitsu split system air con leaking inside the house from the unit
The drain pipe must be plugged up or bent. Lift cover of unit and look for water in the tray, find drain hole and remove obstruccion inserting a piece of wire. Be gentle and careful. After the water in the tray drains out, pour a glass of water in the tray to rinse it out and make sure the drain pipe is completely clear.
While you are at it, clean the air filter of the unit.
Good Luck
Mar 07, 2010 | Electronics - Others
The machine will fill with water and run through the first part of the cycle, then stop. If I turn the setting dial to the next setting the machine will start, but does not pump out the water. At each step...
Have exactly the same problem. At first thought it was broken drain pipe--as I found broken drain pipe searching for a fix for this--coincidence? Anyway, drain pipe fixed, and unit still will not enter spin mode. When unit gets to spin mode, there's an audible click (solenoid), and the unit will not spin or drain the water.
All else is working fine.
What part should be replaced?
Nov 16, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Runs the cycle but doesn't drain completely
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Kenmore Dishwashers
Water remains in drain after cycle is completed. Odor remains in unit before loading is complete (a day or two) before another wash...Normal?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 31, 2009 | Bosch Dishwashers
My unit displays P2 mode flashes red wont turn.....
P2 error indicates that the spill reservoir in the base of the unit is full.
Solution:
Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain (Remember to replace plug.)
Remember...this is not the water tank on the side. This is the water than can collect in the bottom of the unit. Take it outside and drain it
Aug 20, 2009 | Heating & Cooling
Whirlpool dishwasher is not fully draining after cycle complete
THE PROBLEM SOUNDS TO BE WITH THE INSTALLATION OF THE DISHWASHER ITSELF. YOU NEED TO MAKE SURE YOUR DRAIN HOSE IS NOT KINKED AND ALSO THAT THE DRAIN HOSE FORMS A LOOP. IN OTHER WORDS IT SHOULD GO STRAIGHT UP BEHIND THE UNIT AND THEN DOWN INTO THE SINK OR DISPOSAL.THIS SHOULD TAKE CARE OF YOUR PROBLEM.
Apr 07, 2009 | Dishwashers
Hotpoint 22 in. 7892 Built-in Dishwasher Logo
90 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
