Question about DeLonghi DEBIG24SS Gas Single Oven
Model DFG 905 igniter is working but gas wll not stay alight
There is a switch in bottom panel that is part of the igniter it has two wires and has a plunger type connectionype
that is a door switch which locate bottom of panel. If that close ignite will ignite, if the door open the pilot will stop. Hope it help ..good luck
Aug 20, 2014 | Blodgett DFG-100 Gas Single Oven
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Blodgett DFG-XCEL spark but no flame
You need at least 24 volts for the gas valve to open
Jan 21, 2014 | Blodgett DFG-100 Gas Single Oven
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
My oven is gas and has an automatic pilot...but there is no spark ,,,,I can smell a little gas but no ignition
I suspect your silicone carbide ignitor is weak.
I have a nice video on my blog cover page HERE on silicone carbide ignition.
You can get parts, and service manuals for your machine HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 21, 2011 | Blodgett DFG-100 Gas Single Oven
Igniter stays lit entire time oven is on Blodgett dfg 100-1
I have seen this happen when a hole develops near where the ignitor is mounted. The excess gass overheats the ignitor and burns it up. What I do in a case like that is slide a c clamp over the burner and cover the hole.
Apr 12, 2009 | Blodgett DFG-100 Gas Single Oven
Blodgett Oven won't light
Go here,find what you seek. Great Co.
BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Dec 12, 2008 | Blodgett 911-DOUBLE Gas Oven
Gas smell at start up
Be sure that the igniter has a good ground. I mean make sure you clean it well. Be sure its fastened well. And of course that it is close enough to burner. Air flow in building can also hinder lighting.
Nov 14, 2007 | Blodgett DFG-100 Gas Single Oven
Main Burner not lighting
This is caused by a faulty pilot safty valve. it will be the tee looking valve with the red dime sized button in the middle.
Hope this helps You
please rate me
Oct 18, 2007 | Blodgett DFG-100 Gas Single Oven
DeLonghi DEBIG24SS Gas Single Oven Logo
43 people viewed this question
Top DeLonghi Ovens Experts
Naftali Haskell
Level 1 Expert
Mike Teter
Jon Lamb
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
