Question about Hotpoint Washing Machines
I have hotpoint aquarus wma34 i put a wash on last night and when draining or rinsing the water is coming out through the drawer and the door and makes a grinding noise when stationary could it be that the internal filtr needs cleaning out ?
  • Hotpoint Master
  • 3,463 Answers
Could be the filter, or a faulty pump, either of which will give you the symptoms you describe.
Posted on Oct 15, 2010
Wash machine pump doesnt work
Hiya,
some machines have a filter at the front of the machine it will be right down the bottom behind the trim this trim normally just pulls to open & if so you will see a small circle if you unscrew that some water will come out & if blocked will have some stuff in that you can remove,
Hope this helps
Apr 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wma34 washing machine - flooding and clicking
Sounds like it could be relatively expensive to put right.
Personally, I think you would be better in investing in a new washer, more so in view of the fact that is 7 years old.
There are numerous possibilities for the symptoms you describe.
Hope this helps you to come to a decision.
Dec 29, 2009 | Washing Machines
Hotpoint door not locking
i think the problem from what you saying come from { a water level swith} because it contol also the door from opening when the water is still in the drum so it may need to change from the begining >
thanks
Jul 09, 2009 | Hotpoint WMA33 Front Load Washer
All programmes stop before last rinse & spin.
I would suggest you check the filter.
Remove rear panel completely, locate and remove large black hose fastened to bottom of tub.
Remove and clean plastic filter inside hose,, check drain hose for partial obstruction, refit filter and hose.
Make sure drain hose is not kinked or trapped, and make sure outlet is not obstructed.
Refit rear panel, and test.
Please leave a fixya rating for my suggested solution.
Thanks.
Feb 11, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD440 1400 Spin
There has been an unbalanced load and the machine could not spin
(see ‘Automatic Features’, Starting and Programmes).
Has the drain hose been installed correctly (see Installation)?
Are the drain hose, standpipe or undersink connections blocked?
Has ‘Rinse Hold’ option been selected? If so press the Rinse Hold button
drain hose make sure there are no kinks and the end is over the top of washer to drain this ensures that there is no back flush with drain pipe
clean the dispenser drawer regularly
Clean and dry the dispenser
drawer, syphons, grate and
fabric conditioner exit channel
(A). Also regularly clean the
outlet pipe area
Never force the machine door: this could damage
the safety lock mechanism designed to prevent
any accidental opening
May 21, 2008 | Hotpoint Aquarius WD640 Front Load...
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius WMA34
there is a small access panel in all front loaders.  there is probably a coin stuck in the compartment.  this will stop the water pump operation correctly
Oct 27, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Softner still in the draw
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next step !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test with a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Aug 03, 2007 | Hotpoint WF645 Front Load Washer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Washing Machines Logo
87 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
