Make sure you are using a brand new needle--a dull/damaged needle will skip stitches.
As for the feed dogs, if it is a mechanical machine it's possible the machine is seizing from old dried oil.
Wheel on right side that controls the needle up and down is very tight...
SOURCE: upside down stitching
Sounds like the needle alignment is out.
This website has some instructions on how to properly set it up and also has manuals too.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=hf_cs8072eus&Cat=53
try adjusting the thread tension control! a loose setting would cause the problem! try increasing tits tightness!
SOURCE: How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
SOURCE: skipped stitches
Change the needle first and make sure it is inserted correctly. Use good thread i.e.: Guterman or Metler are some. If you are using a stretch material then put a stretch needle in the machine. If you do all this and it still skips then you may have a mechanical problem with the machine. The machine is "out of timing". Have a good tech. look at it. This happens quite frequently on "inexpensive" machines. Sorry.
SOURCE: My Brother LX 3125 does not sew zig zag stitches
Mine did the same thing. The needle is probably to high. Do not insert the needle all the way to the top. Lower it a bit and it should zig zag!
