Question about Sony KV-27S65 27" TV
Panasonic color tv model # ct-13r38sg
I have audio ,put the horzi line only can not open up
  • 4,234 Answers
The problem here is that the vertical IC either has bad connections or is defective. Look for a small flat IC with about 11 pins attached to a heat sink. It will be marked LA7837 or something similar. Try resoldering the pins on the IC first. If that fails to resolve the problem replace the IC.
Keep us posted.
Dan
Posted on Jun 03, 2008
Panasonic color TV model CT-32G9J won't turn on.
been a long time since fixed an crt tv. but if you have a stand by light the problem on this model is the control chip if remember right it sits on the left side near to the front. think its an 8 pin chip. these just go and it will not turn on. these chips are easy to get hold of and are cheap. you just need to remove it and replace with a new one. and the tv will work again. its not on the power board but is controlling the power start up. if there is no stand by light its a longer problem to solve. it could be a number of problems. would need to know if any problems happened before the tv did not turn on.
Jan 15, 2014 | Televison & Video
I have a Panasonic TV CT-34WX50 every time I change channels
it sounds that have problem in the chroma board ( video board ) a small board that hooked up in the neck of the picture tube. if the color is greenish the cause is dead in red video driver transistor or open resistance. hope this can help good luck.
Jul 26, 2012 | Panasonic CT-34WX50 34" TV
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
Need code to mate ONE for ALL to tv
if you goto the remote's manufacturers web site you will get the code from there
May 08, 2009 | Televison & Video
Panasonic color tv model ct-13r38sg 13"
verticle amplifier is not working on your tv
take it to a shop if you dont know.
verticle IC BE CHECKED.
AND ELETROLITIC CAPACITOR feeding verticle scan coil.
Jun 01, 2008 | Sony KV-27S65 27" TV
CT-13R38SG
Parental Lock Feature
Combo's
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Panasonic tv help
my tv screen just turned brown. sound and everything else works fine?????
Panosonic HD tv
Jan 24, 2008 | Sony KV-27S65 27" TV
Where is ny color
HI SIR PLEASE TRY TO CHECK THE COLOUR SYSTEM SETTING SELECT FOR AUTOMATIC OR THE PLACE COLOUR SYSTEM YOU LIVE IN FOR EXAMPLE (NTSC ) FOR USA
Jan 22, 2007 | Panasonic CT-2788YD 27" TV
Tv color
The solder joints on the degaussing thermistor have cracked or the thermistor itself has opened, and the CRT is heavily gaussed. You can degauss (demagnetize) the picture tube and the colors should return to normal, but the thermister should be resoldered or replaced.
Nov 26, 2006 | Panasonic CT-32SF35 32" TV
Sony KV-27S65 27" TV Logo
268 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
