Question about Rancilio Silvia Espresso Machine
I have my Silvia for 3 years and for the last couple week, it gives me espresso watery with no crema. I havent changed anything for the last 3 years. Please help!
  • 26 Answers
It definitely needs preventive maintenance once a year. There could be a couple of issues causing watery espresso. You could have a clogged shower screen or cracked porta-filter basket. They bypass valve from the pump could be leaking causing low pressure (check this by pulling a shot and seeing if water continually flows back into the tank via one of the water hoses).
Mike mikey@espressomachineexperts.com
Posted on Oct 15, 2010
  • Vicomte Oct 15, 2010
    Mike,
    It is maintain regularly. Every 3 months, decalcified, screen, etc... removed and cleaned.
Why won't my portafilter stay engaged once the water starts dripping? It flies off and sprays coffee grounds, and this started last week. Stays in place only if I wrestle with the filter handle.
It is possible that the grind you are using is too fine and causing so much back pressure that the portafilter is moving, also possible that the group gasket installed need to be replaced, I have also seen this happen with damaged screens.
Jul 27, 2015 | Rancilio SILVIA EXPRESSO MACHINE Silvia...
Hi, I have an 8 year old Silvia...cleaned often, only use purified water in it. Recently, it has not been able to reach steam temperature. I end up with watery milk, as the steam wand is producing s
It is possible that the thermostat for the steam is not operating or need to be reset. There are 3 in the silvia machine. Remove the four screws on the top to gain access. Unplug machine before doing any maintenance first.
Mar 18, 2014 | Rancilio Coffee Makers & Espresso Machines
I am not getting crema with my new machine. What do I need to know?
Either your coffee grind is too coarse, or the coffee is not fresh, or your tamp is incorrect. Those are the 3 basic thing that affect your crema. Try this get a handful of coffee and squeeze it tightly, it should clamp and then break apart when you open your hand, you should also be able to see your finger marks in the coffee.
Jan 04, 2011 | Rancilio Silvia Espresso Machine
I have a Silvia which is about 6 years old. Over the last few weeks, when I am brewing coffee, some water leaks around the portafilter. The portafilter is well seated and properly tamped. How do I approach...
Have you ever changed the brwe head gasket? It should be changed yearly at least. They get hard from the heat and won't seal. They should be soft to make a good seal. You can change it your self. I have left post on changing gaskets. Look for Silvia solutions.
Nov 14, 2010 | Rancilio Silvia Espresso Machine
New machine but no crema.. very disappointed
I have the same machine with excellent crema. You need to be sure you are using a high quality burr grinder on the fine setting. Also be sure to tamp using a tamper for even compression. The espresso should come out SLOWLY and smoothly... it will end with a great crema.
Jul 28, 2010 | Rancilio Silvia Espresso Machine
Diminished pressure when brewing espresso
try adjust grinder,try go litlle bit courser ,check screen it need to be clean.
Aug 22, 2009 | Rancilio Silvia Espresso Machine
Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Jul 16, 2008 | Gaggia Titanium Espresso Machine
UNABLE TO GET GOOD CREMA ON TOP OF COFFEE:
It could be. Your grind should determine the amount of time that it takes the shot to pour. Standard is 18 - 30 seconds. I prefer 25. If it only takes 10 sec, your crema will be weak.
Are your beans fresh? Older beans produce less crema. By old, I mean more than a month if properly stored.
What is the temperature of you shots? The water coming out of the head should be about 195 F which makes the shots roughly 170-185. If it's too cold, you'll get worse crema. It's also possible to have mostly steam in contact with the grounds which will give the same results. Both indicate other problems.
Make sure your group head screen isn't clogged. And make sure everything is very clean, especially inside the handle (under the grounds basket - just pop it out with a screwdriver). Good luck!
Dec 16, 2007 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
307 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
