Question about Samsung HCL4715W 47" Rear Projection Television
Would you have a list of the different resistiors???
I was looking at your comments on the hcl4715w sets. I was also interested in the biasing resistors. Might you have a list of the resistors I would need as well to save on shipping???
  • Samsung Master
  • 8,617 Answers
270 Ohm 1/2watt
27K Ohm 1/16 watt
3.3K Ohm 1/8watt
3.9 Ohm 2 watt
150 Ohm 2watt
Posted on Jun 03, 2008
Fix the 3d look on my rear projection samsung model hcl4715w. it is a 2001
Read Chapter 3 about adjusting the convergence controls. These are to do with the alignment of the colours. It will help you fix the 3D look.
TVs
Sep 11, 2014 | Samsung HCL4715W 47" Rear Projection...
Tip
Look out for brands and manufacturers
Even if you do not want to comment or display bias, several manufacturers Of Flat-screen TVs are listed in the production of television sets consume Less Energy. For example, philips has won a european geen television of <br /> <br /> the award in Its 42-inch LCD screen. united states, the natural resources defense council, thanked the panasonic significantly reduce the power consumption of newer drives.
on Dec 22, 2010 | Televison & Video
Acer model AT3201W no picture?? Sound is great, everything is connected tightly. Checked the manual ...no help..
There are several things that could be the problem, as usual. However I did manage to get a set working with the following characteristics:
- Set powered on ok and displayed the Acer logo fine.
- All of the inputs had very low brightness and poor colour.
- The backlight was working and appeared bright.
- The picture was barely usable with brightness/contrast set maximum.
I figured the issue here was a loss of the picture settings in the eeprom in the unit. So I set about to find how to get to the factory menu to set these things. This assumes you can get a menu to display on the set.
To enter factory mode on the remote control press menu/menu/234/menu. You will see the menu displayed with some info in the top bar that is normally not shown.
Then on the front of the TV press Volume- and Channel+ at the same time and hold until the factory menu appears.
You may see that the RGB gain and bias values are low or 0.
If that is the case set the colour temperature mode to Standard and then adjust the RGB gain and bias values to the following:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
Then set the colour temperature to Cold and enter the following values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 300
B bias: 310
Similarly, for Warm adjust the values to:
R gain: 434
G gain: 482
B gain: 484
R bias: 300
G bias: 280
B bias: 264
Then, if this was the problem, the picture should be fairly adequate.
Hope this works for you...
BTW I must give some credit here to another poster who provided a similar solution to a different problem here:
http://www.fixya.com/support/t154524-tv_losing_its_channel_memory
May 07, 2010 | Acer AL2671W 26 in. LCD Television
Samsung hcl4715w green warped after power surge
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | Samsung HCL4715W 47" Rear Projection...
Anyone need any parts for the HCL4715W? Parting mine out.
More then likely set has 2 burt resistors on convergence board 2.7ohms
Jan 27, 2009 | Samsung HCL4715W 47" Rear Projection...
Tires
The main difference between radials and bias-ply tires lies in their construction. Tires aren’t just toroidal balloons, they are reinforced with cords of steel or synthetic materials such as nylon or Aramid. In bias-ply tires, the fibers are wrapped in an X pattern between the beads; in radial tires, the fibers are wrapped perpendicular to the tread. Radial tires have more flexible sidewalls than bias-ply tires, and thus absorb road irregularities better and have a comparatively larger contact patch when leaned over. Because of the flexible nature of a radial, these offer higher mileage compared with a comparable bias-ply for a given rubber compound. Since they absorb small road irregularities better, they ride more comfortably and are less likely to be upset by groovy pavement. While radial tires perform better than bias tires, some older motorcycles can’t be fitted with radial tires because of differences in rim profiles. You probably won’t notice much of a difference anyway, so stick with boas tires if that’s what the motorcycle was designed for.
Nov 20, 2008 | 2008 Harley Davidson VRSCDX Night Rod...
Who might know the resistor vaues I would need for the convergence board???
The 010. 020 and 040 ICs are interchangeable with the 392-040 ICs being better. The site I posted has origional sanyo ICs you can get them cheaper but when it comes to convergence ICs you end up getting what you pay for if there under 20.00 each they arent sanyos. I dont know of any kits for samsung Hitachi selld kits but they wont have the one your model needs, The convergence resistors are special metal films so most places wont stock them
Jun 02, 2008 | Samsung HCL4715W 47" Rear Projection...
Dark picture problem
Sounds like he just turned up the drive bias. I would get him back to put it right.
Mar 20, 2017 | Mitsubishi VS-6041 60" Rear Projection...
Download
You have this listed in a camera group, but from the entire question and comments, it seems like an OS question. I will answer this as an OS question, if it's not, please clarify with comments and what camera you are working with. Thanks.
If your interested in having your XP OS look like Vista, there is a Vista Transformation Pack you can obtain from here to accomplish this.
Nov 23, 2007 | Cameras
TV losing its channel memory
I had the same problem. I replaced the EEPROM marked U33 (it's a 24C32 in a smd package) and the TV worked fine.
BEFORE replacing the EEPROM you have to go into the Service Menu (hold down VOL- and CH+ on the local command) and take a note of all the values, specially the R,G,B gain and R,G,B bias, in the "standard" picture mode as well as in the "Cold" picture as well as in the "Warm" picture mode.
(if you forgot to do this, here are my default values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
then you put the "Cold" image mode and set again those values, increasing the G bias to about 300 and the B bias to about 310.
then put the "Warm" image mode and set again those values, increasing the R bias to about 300 and the G bias to about 280)
The other values such as brightness, contrast etc, have to be left at 50.
I hope this solution will FixYa!
Jun 16, 2007 | Acer AL2671W 26 in. LCD Television
Samsung HCL4715W 47" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
