Question about AT&T 2256 Cordless Phone
Cordless house phone, 2 of them, just say connecting
  • 410 Answers
PLEASE TELL THIS PROBLEM TO YOU OPERATOR AND ASK THEM TO REFRESH YOUR CONNECTION.......MAY BE IT WILL WORK...
Posted on Oct 15, 2010
Why does my house phone have a dial tone, but the cordless ones do not?
Is the cordless phone base station connected into the phone line in the wall?
Aug 17, 2014 | Lands Phones
Cordless phones
1) unplug all phones
2) plug them back in and check line.
If you still have the issue,!take a corded phone with. Phone jack coed to your box on the outside of the house. Usually gray, unscrew the first box - you'll see modules there - the one with the last four of your phone number is the module we'll use. Follow the directions on the box to open that module - plug your phone into the module. Here's the important thing - if you don't hear static, then the problem is from inside your house. If you call att to come out they will charge you - but that's the whole unplug the phones and centralize your base better. However, if you still hear static in the outside box, it's an att issue and have to come out at no charge.
Jun 24, 2014 | Panasonic KX-TG1033S Cordless Phone
I have a DIR 615 Dlink wireless router connected to a Dell computer running XP Pro. Checked for latest firmware, had it. About every 2 or 3 days it will stop broadcasting a signal and I can not logon with...
Ok this might be a bit tricky but it sounds like there is another wireless signal that may be interfering with yours.
Do you have an older cordless phone in the house? If so try and move the cordless base farther away from the wireless router. Even if they are on different floors in your house, if they are located near each other the cordless can interfere with the wireless signal.
The other possibility is that there is signal that is coming from the outside of your location and is causing the interference.
I know that when I had an XP Pro machine (Laptop) it would drop the wireless signal every couple of days or so. I traced my problem to my neighbors cordless phone. he had an old one and it was near the side of my house that my router was on and it was causing me problems so I move my router and the problem went away.
hope this helps
May 21, 2011 | D-Link DIR-615 Wireless Router
I own 5 Uniden cordless phones. On 2 of them there is a constant buzzing sound which continues no matter where I plug them in anywhere in the house.
If they are cordless what do you mean "plug them in"?
If you are referring to charging them the maybe your AC is bad.
Mar 02, 2011 | Uniden Cordless Phone
I don't get a dial tone when I pick up the phone both the base and the extention both are dead but I have a fax machine also on another line and it works ok
to test the phone system. unplug the phones that are not working from the telephone jack. Install a phone on that phone jack that you know works (an old one or a cheap new phone). If the new phone works on the phone line in question, then your cordless phones are the problem and not the house phone line. If you plug the known working phone into the wall and it now does not work, then you have a problem with the wall outlet or the connection to the house. If it is a phone line or house connection problem, call your phone company. If it is your cordless unit, try them at a different phone outlet or at some other house to see if they work anywhere.
Dec 24, 2009 | Uniden Cordless Phone EXAI985
I'm looking for the user manual for the Uniden
cannot speak or receive phone call on the 2 dect phones at the same time; am able to hear from one uniden and land-line phone in the house at the same time.solve this
Are there English translations of the owner's manual? solve this
Dec 04, 2009 | Uniden Cordless Phone
Uniden 5.8 GHz Digital cordless w 3 handsets interference background noise no matter where we are in the house or which handset we use
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
Oct 06, 2008 | Uniden Cordless Phone
I lose my wireless connection when the house phone is in use?
Is the house phone a cordless handset? Some cordless phones cause interference with wireless devices. Try either changing the channel on your wireless router or changing the channel on your home phone. If that doesn't work, try getting a new handset from a different manufacturer.
Apr 02, 2008 | Computers & Internet
Transmission band
The information you got with the phone will tell you the optimum distance the units will work from each other, remember these are ideal conditions, foil insulation and other types of barriers may shorten this path. I don't believe you will have any trouble because most houses are not large enough to breach the specifications. Thank You. Jerry
Feb 11, 2008 | Uniden Cordless Phone
Cordless phones will not connect to base.
I just had the same problem and tried several things with no results. Then, I figured I had tried everything else so I just unplugged the battery pack, set the phone down for 25 minutes and then plugged the pack back in. Phone worked again after that.
Oct 09, 2006 | Sony SPP-S2730 Cordless Phone
AT&T 2256 Cordless Phone Logo
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
