Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Subzero 650 not running
Hi, i opened my fridge this afternoon and it is dark in there! do i need to sechedule a service call? or is it somehting i can fix myself?
  • jchemis Jun 03, 2008
    thanks for your response, however, the problem was taht the door evidently had not been completley closed for some period of time. The lights evidently turn off to avoid geting too hot. After closing the door properly for a period of time, the lights came back on. thanks again!
  • 828 Answers
Check the light switch on the door frame, if that doesn't do the trick change the light bulb. If your refrigerator is not running and cooling and the light is out check the power, plug & circuit breaker in the power center.
Posted on Jun 03, 2008
Subzero 650 LCD dark. Lights in fridge out. Lights in Freezer on. Unit still working. Any thoughts?
Most likely door switch assuming of course the bulb has been replaced
Nov 13, 2017 | Refrigerators
Flashing ice light service
Along with the service light, are you getting any fault codes with it (like EC and a number)? Under normal conditions, this would mean the the unit as a whole is running too much and needs to be cleaned. If cleaned and this is still an issue, you may need a certified person to look for cooling issue that only the computer is seeing. This can happen in a unit the is about 10-15 years old, normally in the fridge section. Do you have a ice ball or frost on the the back wall of the fridge section around the meat slide shelf? this would b a tell - tell sign of a cooling issue. If in doubt, call SubZero dIrectly at 800-888-7820 ask for a certified dealer to take care of you. Not every service company can work on the SubZero unit. (You want certified!)
I hope this helps.
Oct 10, 2013 | Sub-Zero 650 / O Bottom Freezer...
Subzero does not cool sufficiently, even with cool
yes you have 2 compressor. ona for fridge one for the freezer..
Nov 29, 2009 | Sub-Zero 650/SRH Stainless Steel
Subzero 650: Ice Service light on
turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
Jun 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Jun 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Left Door open now it wont power up
you can un plug it for 30 minutes to an hour and plug it back.
hope it would run normally.
tnx 4 using fixya,
drcool
Sep 27, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero door left open - now acting strange
You have probably already figured this out, but if the door is left open there is a sensor that will turn the lights off to keep the fridge from overheating. After you close the door and let it sit with the lights off for 15 minutes or so, the sensor will cool and allow the lights back on. If the temperature reading in the window is ok and does not say "service" or "vacuum condenser", then you should have no more trouble.
May 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
251 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
