Question about Toys
My rc helicopter won't turn left and right anymore
SOURCE: will not stop spinnig to the left
The heli will do that if you hover less than 1meter from the floor ! or you may need to adjust the swash plate screws Look at them very carefully and draw a diagram if you remove a screw and replace screw into another hole , in case you want to put it back as it was?,Also remove two of those little [8]shaped hooks that tie the blades to the main shaft. Remove one from the top A set of blades and one from the Lower B set of blades You dont need to have all four connected at once.If you click on this link http://www.maplin.co.uk/Media/PDFs/N32FR%20manual.pdf it has the complete operating manual of your apache model in Pdf form (U Will need to download Adobe reader)
Posted on Jan 26, 2010
jyackle5
  • 8197 Answers
SOURCE: Building a RC helicopter for college
You might want to get on google and search how to build Remote Control Helicopter. you will find a lot of useful info. If you have never flown a RC heli thought I suggest you get a sim for the computer. I have been flying now for 10 years and they are not that easy to fly. I still have problems and always am learning some thing new. here is one link to look at.
http://www.angelfire.com/blues/heli_project/
Posted on Jan 30, 2010
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
  • 906 Answers
SOURCE: find charger for world tech rc helicopter skyhawk
good day,
hope this link below will help tp solve your problem.
toys
Posted on Jul 29, 2010
Don3542
SOURCE: My helicopter won't take off,
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Posted on Jul 11, 2011
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
Skygiant rchelicopter when i sync it and then give it throttle all the lights on the helicopter syart flashing red and it dosent do anything
I bought 2 off brand ,of the same remote controlled Helicopters which cost about $30.00 each. The controller has A_B_C setting helicopter has none, You can set them up any way, either all on one or separate channels per controller which is channel A.
1st turn off Helicopter switch to off and controller off .
Set controller -1 to channel C , , then (controller-1 ) throttle knob to max, turn power on to controller -1 , throttle down and up 3 cycles and left and right 3 cycles
Turn on Helicopter 1 with controller -1 still on, it should work on channel C
Jun 11, 2014 | Team International Hawk Talon V3 RC Indoor...
Helicopter will not fly, just goes in circles
try pressing right or left on the remote or try flicking the joystick forward slow
Feb 17, 2014 | RC Helicopter Select Sanhuan SH 6030 C7...
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
My rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
May 13, 2010 | Radio Shack Indoor Micro Mosquito Rc...
How do i fly my spin master air hog rc helicopter all it does is go in circles
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
My helicopter spins to the left
theres trim on the remote just hit the r until it stops spinning to the left and it it spins the right then hit the l
Jan 07, 2009 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Toys Logo
279 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
