Question about Bowflex Revolution Home Gym
My Bowflex Revolution "squeaks" when used...the sounds comes from the rub of the inner portion of the spiraflex plates against the steel rod that they turn on. Any suggestions on how to eliminate this "sqeaking"?
My ignis Bella 60 front load washing machine inner tub has developed sideways play . It rubs against sides during cycle with soft rubbing sound and stucks
at the back of the washing machine is an inspection plate not large
turn off the power and pull the plug from the wall and turn it from the rear and see what is happening
Mar 28, 2015 | Washing Machines
Tip
Bowflex Revolution Assembly Manual Download
Download Bowflex Revolution Assembly Manual
Would you like to review the features of the Bowflex Revolution Home Gym?
Have you lost your Bowflex Revolution Home Gym Assembly Manual?
Would you like a digital, searchable, pdf version of the Bowflex Revolution Home Gym Assembly Guide?
Follow this link (& click FREE) to download a pdf version of the Bowflex Revolution Home Gym Assembly documentation.
I hope that helps.
___________________________________________
Download Bowflex Revolution Users Manual
on Jul 03, 2010 | Exercise & Fitness
Tip
Bowflex Revolution User Manual Download
Download Bowflex Revolution User Manual
Have you lost your Bowflex Revolution Home Gym Owners Manual?
Would you like a digital, searchable, pdf version of the Bowflex Revolution Home Gym Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bowflex Revolution Home Gym documentation.
I hope that helps.
I have a 2002 gmc sierra 2 wheel drive and when I take off initially and when I turn left I hear a grinding/grumling noise.
Loose or damaged Wheel-Bearing causing other parts to rub together, like the brake components or your wheels are too big or shocks weak, or exhaust hanging and are rubbing against something.
Perhaps oil is leaking from your rear axle housing dut to bad seals (check inner of wheels) and around axle housing - remove plug and check that your finger can reach in and touch it. Could be a sign of rear end failure or simply the backing plates on the brakes behind the rotors and the drums (steel disk) sometimes rust on the drums can grind against the backing plates if they are weak or warped (clean this area).
Jun 15, 2010 | 2002 GMC Sierra 1500
Steering pulling to the right
Yes your car has outer tie rod ends.The steel on steel noise could be the metal plate behind your brake rotor could have got bent a little and is rubbing on the brake rotor.
Jun 15, 2009 | 1994 Nissan Maxima
Tip
I hope that helps.
on Jul 03, 2010 | Bowflex Revolution Home Gym
Tip
I hope that helps.
I put one the first weight and locked it in i didn't know that you had to put all six and then lock it in. How do i take the one i put on off and start over
You should be able to take off the plates by turning them the opposite direction as putting them on. If you look at the plate you'll see the grooves that lock each one together. You just need to twist the plate you want off and twist it out of the grooves. Once out of the grooves it will turn back to normal, releasing the tension on the bands inside. You can then just slide it off the bar. The perm attached 5# plate tends to turn too. You need that one to be stationary. If you can't do it alone, have someone hold the perm 5# plate steady as you turn 'off' the additional plates.
May 03, 2009 | Bowflex Revolution Home Gym
Bowflex Treadclimber rubs against housing.
Adjustment is needed. Remove rear covers and using a 9/16 wrench lossen the four bolts that secure treadle assembly to base. Place a 3/4 inch piece of plywood or a 3/8 inch socket extension in between the treadles in the front area. with that in place center them about an 1/8 in closer to the right upright as when you tighten the four bolt up the drive belt will place additional pressure and they should center perfect. tighten bolts...tight. remove wedge from between treadles and recalibrate unit. replace covers and enjoy. Use turtle wax on area rubbed to prevent rust.
Mar 05, 2009 | Bowflex Treadclimber TC5300
Pulley system "off track" inside main frame of 2005 boflex revolution
I had same problem. I fixed it by taking plastic sides off using a long phillips head screwdriver. Jay, you don't have to take the sides off to fix your problem. The sides come off only to untangle and rewind cables on pulleys. Pull the cables all the way out. Have a helper pull out and keep holding out the tension knob This is shown at the bottom of page nine in the manual. With someone holding the tension knob out turn the large pully located beneith the tension knob CLOCKWISE! I screwed mine up by turning it counter-clockwise. This winds the handle to the top and if you start with all the cable pulled off the pully, the cable should then wind itself nicely back onto the pully. Once the handle is all the way up, with the round ball on the cable jammed up against the pully, then and only then let go of the tension knob and let it fall back into place. If the handle falls down a few inches repeat this proceedure but push lower pully a bit harder and try to turn tension knob, while it is pulled out, in the opposite direction and it will then click into place one notch tighter and should hold the black ball on the cable firmly against the pulley. Let me know if this was helpful.
Adam
Oct 21, 2008 | Bowflex Revolution Home Gym
Bowflex Revolution Home Gym Logo
212 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
