Question about Franklin RF-192
Replaced the batteries new sony cr 2032 when I power up get a message "R FAIL" tried resetting no avail . Please help...
  • 410 Answers
What was that message.......
Posted on Oct 15, 2010
Acer Aspire X1700 clock needs to be reset every day
You need to change the battery (normally a CR-2032 - which is available everywhere).
Unplug the computer, remove the cover, and set it down with the motherboard facing up. Look in the corners for a battery holder and the battery (it may be under a PCI card - which you will have to remove before changing the battery). When you locate the battery, very carefully remove it and replace it with the new battery. Replace all parts (seating the boards correctly) and button up you computer. Re-install the cables and turn it on.
Mar 09, 2015 | Acer Computers & Internet
Www ehow com
Cmos battery is usually a 3 V button battery, there are variety of different brands so you need to open and check it.
eBay: ACER ASPIRE 7741G 334G50 MS2309 CMOS BATTERY - 476
http://www.ebay.com.au/itm/ACER-ASPIRE-7741G-334G50-MS2309-CMOS-BATTERY-476-/161408573087?pt=AU_Components&hash=item2594b35e9f&_uhb=1
2035, 2032 can be bought from any super market or hardware store. Need to open the PC, locate the battery, which is normally clipped to the mother board. Use a small screw driver and lift out. If battery is soldered to the mother board then need to access under the board and de-solder carefully without damaging the tracks.
2032: CR2032 CR 2032 5004LC 3V 3 Volt button cell lithium battery for CMOS
http://www.ebay.com.au/itm/CR2032-CR-2032-5004LC-3V-3-Volt-button-cell-lithium-battery-for-CMOS-/271586313364?pt=AU_Electronics_Batteries_Chargers&hash=item3f3bce4494&_uhb=1
solder types: SONY CR2032 3V SOLDER TAB Pin battery with soldering tag for CMOS Bios PLC new
http://www.ebay.com.au/itm/SONY-CR2032-3V-SOLDER-TAB-Pin-battery-with-soldering-tag-for-CMOS-Bios-PLC-new-/271570170168?pt=US_Single_Use_Batteries&hash=item3f3ad7f138&_uhb=1
Aug 30, 2014 | Acer Aspire Z5771-UR31P - All-in-one - 1 x...
Amano pix-55 battery replacement how to
The Pix-55 has a simple CR-2032 coin battery. But the battery contacts are pin-point spot welded to positive and negative faces instead of being easily replaceable as they should be. I carefully broke the battery loose and soldered the leads from a single CR-2032 coin battery holder I got off Ebay, The green electronics board is marked +&- so easy to get the leads right. Before I started, mine didn't work at all and after the new battery it works great. What a shame many of these are probably thrown away because of a $2.50 battery. The next time mine goes bad I can easily replace it.
Feb 14, 2014 | Amano Pix-55 Time Clock
I keep getting a message that the battery needs to be replaced. Where is it?
It is on the motherboard. Take the power cord off the unit and panel to access it. On the board is a small round battery which is about half an inch in diameter and silver (chrome plated) somewhere on the board. Usually a CR 2032. It is what powers the memory of the CPU. Cost is around $2.50
Sep 27, 2012 | Gateway FX6803-35 (PTGBD02004) PC Desktop
What is the type cmos battery for the asus eee pc 1005hab
Hello alaskavet77,
i found this website where in they are selling batteries for all of the units/systems maybe it will resolve your question
http://www.battery-center.net/asus-eee-pc-1005ha-battery.html or you may wanna check this website
http://www.global-laptop-batteries.com/asus-laptop-battery/Asus-Eee-PC-1005HAB-Battery-Black.html
thanks :D
archiecruz30
Apr 05, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How do I put in a CR 2032 battery. Is it the side with words facing you or not
It really depends on what you are attempting to place the batteries in. However, as a general rule the small side, which is the positive side (+), faces downward. It will either work or it won't should you place it in the incorrect way.
Oct 26, 2010 | Sony Lithium Coin Battery CR2032
When I turn on the Saturn and place a game in the drive. and close the door. It gives me a message drive door open.
Sounds like the CD tray is not closing. Try opening up your Saturn and checking on the top-left corner, next to the part you plug your power cable into. There is a small switch that the CD cover presses on, try holding it down while you turn it on with a game in it and the top half of the case off. The game should spin and play. If you tape it down, it should work fine. If that didn't work, try replacing the battery. The battery you need is called a CR-2032. You can get this at you local CVS, Wal-Mart, or any place that sells watch batteries. After you do that, simply pop off the back panel, take out the CR-2032 battery, and pop in the new CR-2032 battery and then it should work. If that worked, congrats for your Sega Saturn being back in action.!
Aug 11, 2010 | Sega Saturn Console
Which battery does the biostar M7VKB have?
If its the internal CMOS battery then u are right....................sodeep
Jun 13, 2009 | Biostar M7VKB Motherboard
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Feb 02, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
BOOT falilure after RAM installation
Did you make sure that the new RAM was compatible with the motherboard? ...?
Some RAM manufacturers are not compatible with certain motherboard manufacturers....
Aug 20, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
Franklin RF-192 Logo
Top Franklin Computers & Internet Experts
Andrew Taylor
Andrew Taylor
obsteiner
 steve
steve
Are you a Franklin Computer and Internet Expert? Answer questions, earn points and help others
