Question about Lakewood HV-9/C Floor / Box Fan
How do i get a manual for a HV-21-T floor/box fan
2 Suggested Answers
mcdevito75
  • 1970 Answers
SOURCE: are replacement motors available for these fans?
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Posted on Jul 28, 2010
I have an old circular floor fan, that hums and wont come on, then suddenly it comes on?
You need to clean it and oil the bushings. When this doesn't solve the problem, change the start capacitor. If it continues to hum or make noise, replace the bushings. A repair technician may be helpful.
Jun 24, 2014 | Lakewood HV 18-c Floor / Box Fan
Hello i have a hv-180 18" when i plug it in
Yes. These fans have thermal protection in the motor, as well. The thermal fuse or thermal breaker may be bad.
Mar 09, 2011 | Honeywell HV-180 18" Commercial Grade...
All of the sudden my fan stopped working completely. It does have a lot of dust in it. It is 12 inches and says Model HV-9 C. I tried to plug it in several different plugs, still doesn't work.
take front off of fan. then blow the motor out good to get rid of dirt and dust. also when apart oil the front and back of armature, to make it run better.
Oct 20, 2010 | Lakewood HV 18-c Floor / Box Fan
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
HV-180 fanFan has dust on enclosed blades and on cover. Would like to clean. How?
The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
May 28, 2010 | Honeywell HV-180 Floor / Box Fan
Fan shows that the power is on, but fan not running
Dust is evil to all mechanisms!! Keeep UNPLUGGED..then Vacuum all accumulated lint in fan motor assembly, and soak with WD-40...I just did detailed dust cleaning with toothbrush....Fan now runs awesome!! Good Luck
Sep 06, 2009 | Lakewood HV-18 Floor / Box Fan
Need a source for a blade for a Patton U2-1887 fan
Try McMaster Carr -- page 640, Fans and Fan Blades.
http://www.mcmaster.com/#ventilation-fans/=8qgdv5
Aug 29, 2009 | Lakewood HV-18 Floor / Box Fan
Does the lakewood fan have a fuse that can be replaced?
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
Aug 26, 2009 | Lakewood HV 18-c Floor / Box Fan
Speed indicators light up but no fan operation 18" floor fan.
Your fan speed control module is probably shorted and is damaged. Have it repaired by an electrician.
May 01, 2009 | Lakewood HV 18-c Floor / Box Fan
Need help troublshooting floor fan problem
This problem is caused by worn brushes, these are probably not replacable. You could replace the motor but you will have more money tied up in that then replacing the fan.
Jun 24, 2008 | Lakewood HV 18-c Floor / Box Fan
Lakewood HV-9/C Floor / Box Fan Logo
46 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
