Question about IBM Wheelwriter 30 Typewriter
Our model 1000 typewriter goes on and then after all lights go on it shuts off.
  • IBM Master
  • 3,594 Answers
Most likely a board or power supply. But if you are gutsy remove the PC board look for debris especially metal on and under the board.
DickyO
Posted on Oct 18, 2010
Why does my wheelwriter 1000 lexmark typewriter makes this hummin sound as though its stuke.
Lube the round chrome rod that goes throught the carrier, Carier is what hold the ribbons and daisy wheel.
Lube pulleys on the belt. You may need to lube the carriage return motor too.
Aug 21, 2014 | Lexmark Wheelwriter 1000 Typewriter
Lexmark wheelwrite 1000 typewriter- print solenoid printer not striking paper
the solenoid plunger makes contact with the print hammer. there is a nylon cap on the contact end of the plunger that goes bad and needs to be replaced not an easy job unless you have done it a few times
Jun 17, 2014 | Lexmark Wheelwriter 1000 Typewriter
ELECTRICITY WENT OUT AND EVER SINCE THE TYPEWRITER 1000 WON'T DO ANYTHING LIGHTS 1 AND 2 BLINKING ON THE BOTTOM RIGHT SIDE, NOTHING ELSE WORKS
This usually indicates a bad keyboard, See my tip under WW1000 or send me your K.B. for a rebuild 100.00..
DickyO
216-216=269-3918
Aug 29, 2012 | Lexmark Wheelwriter 1000 Typewriter
How do you remove cover on Lexmark 1000 ?
On both sides almost all the way to the back of the base there is a slot insert a screw driver thru the top of the slot to release the latches, the cover will lift towards the front, BE CAREFUL OF THE FLAT CABLE THAT THAT GOES TO THE LIGHTS.
DickyO
May 14, 2010 | Lexmark Wheelwriter 1000 Typewriter
Keyboard not working at all. The number 1 light and 2 light are both blinking.
WW 1000 are notorious for bad keyboards, see my tip under WW 1000. If that dosen't work contact Geo. Beyers Co. @ 1-800-392-8085.
DickyO
Oct 16, 2009 | Lexmark Wheelwriter 1000 Typewriter
Beeps and Flashing Lights
It sounds like a keyboard but you didn't give a make or model, if it is an IBM Wheelwriter see my tip under WW 1000
DickyO
Nov 25, 2008 | IBM Office Equipment & Supplies
Lexmark 1000 freezes up light blink
All the lights blinking usually means the batterys are dead or incorctely installed. Leave the machine plugged in and turned on when changing them so memory is not lost.
Nov 05, 2008 | Lexmark Wheelwriter 1000 Typewriter
Lights blink and machine beeps
Check the flat connector that goes to the indicator lights the edge of the keyboard sometimes wears into itand causes a reset sequence.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 1000 Typewriter
Lexmark wheelwriter 1000
Check the keyboard connections. Open the top cover and look just below from the top. You will see two ribbon cables. Make sure they are fully inserted. Are any of the keyboard lights flashing?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 21, 2007 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
