Question about Panasonic Toughbook CF-27 Notebook
Where is the ethernet cable connected to this laptop
  • Panasonic Master
  • 5,125 Answers
This is an older laptop that comes with a modem (RJ-11 on the back), not an ethernet adapter onboard. You can try to get a PC card ethernet adapter (type 2 or type 3 fit the slot) or a USB ethernet adapter. The USB port was not available on models that came with WinNT.
I wish I could be of more help.
Posted on Oct 15, 2010
I have a toshiba satellite l755d-s5359 part no. Psk32u-01w00n Serial my laptop turns on but says I need to fix the Ethernet connection cable. I have never used said cable
Well, what you need to do is to use the Ethernet cable on your laptop.
1. Connect an ethernet cable to your laptop and see if you are getting any connection. If not, then you just need to do the following
Go to the Toshiba website, go to Downloads and Support, then download the LAN (Network) drivers from there and install them in your laptop, that should fix your problem
Oct 20, 2015 | Toshiba Computers & Internet
Tip
How do I Connect an Apple Mac Laptop to the Internet Via a Broadband Router on...
  1. Connect one end of an Ethernet cable to the Ethernet port located on the back of your Apple Mac laptop.
  2. Connect the other end of the Ethernet cable to the Ethernet port located on the back of your Comcast broadband router.
  3. Power on your Apple laptop and broadband router.dont forget to leave youe comment by saying how helpful this tip is to you
on Oct 08, 2010 | Computers & Internet
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
How can i get my laptop connected to the internet using ethernet cord coming from a home cable modem? i unplugged ethernet cord from home pc to my laptop and don't know where to go from here.
You could just connect the ethernet cable from the cable modem to a etherner slot on the Laptop and access internet. NOthing else is required.
Hope this helped.
Feb 13, 2011 | Dell Studio 1535 Notebook
Can I use USB Cable direct to laptop from modem? Ethernet cable from modem is connected to router which is connected to desk top PC. OR should I connect a ethernet cable from router to laptop? Type of...
Hi Friend, It depends that whether your router is wireless or wired. If it is a wireless router then there is no need to connect the laptop with the cable, you can use the laptop wirelessly If it is a wired router and as you said that the Desktop is already connected to the router with the cable so in that case you have to get another ethernet cable and can connect it from the router to your laptop
Dec 08, 2010 | Computers & Internet
Cannot connect laptop with the eithernet cord
If you cannot connect your laptop using an Ethernet cable, make sure the laptop's wireless ethernet is disabled. To disable it in window xp, click the Start button and open the Control Panel. Double-click Network Connections. Right-click Wireless Network Connection and select Disable from the drop-down list.
04e3ee0.png If you are using a laptop with Windows Vista, click the Start Button and type Network and Sharing into the Start Search box. Select Network and Sharing Center from the Programs list. Select Manage Network Connections from the left pane of the window. The Network Connections window will open. Click on Wireless Network Connection. Select Disable this Network Device at the top of the window.
9a7c8c6.png Troubleshoot the Network
After disabling the laptop's wireless connection, be sure to restart the computer before trying to connect with the Ethernet cable again. If you still cannot connect the laptop to the network with an Ethernet cable after rebooting, check to make sure there is not a problem with the network itself. If there are others nearby connected to the same network, such as in your office, dorm or another public location, ask them whether they are currently able to connect to the network. If no one else is using the network, contact the system administrator or your Internet service provider to see if there may be an outage. This step can save you plenty of time troubleshooting if there is an outage in your area!
Troubleshoot the Ethernet Cable
If there is no problem with the network itself, the reason that you cannot connect the laptop may be the ethernet cable. Make sure that the Ethernet Cable is securely connected to both the laptop and the wall outlet. If possible, try connecting the Ethernet cable into another wall jack or port on the router, and then try using a different Ethernet cable. The Ethernet cable you are using may be damaged.
8686681.png Troubleshoot Network Settings
If the Ethernet cable does not seem to be the reason why you cannot connect to the network, check the laptop's network settings. In Windows XP, open the Control Panel and select Network Connections. Open Local Area Connection and check the status of the connection.
In Windows Vista, go to the Network and Sharing Center and select Diagnose and Repair from the left pane and wait for the results.
If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
If it says that the network adapter is unplugged and you have ruled out a problem with the Ethernet cable and port, the laptop's network adapter may have failed. Try using the same Ethernet cable on another computer. If you are able to connect to the network on another computer using the same Ethernet cord, contact the laptop's manufacturer, a computer repair technician or replace the network adapter yourself.
fc4831a.png If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
Oct 28, 2009 | HP Pavilion dv6000z Notebook
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
Last week I put a 4-hub on my desktop and laptop. one wire from wall to main hub, one ethernet cable from hub to laptop, one ethernet cable from hub to rear ethernet port on desktop. The internet on the...
check if we are getting good ip address 192.xxxxxxxxxxxxxxxxxx
not the 169.xxxxxxxxxxxxxx
relese renew if 169.xxxxxxxx is the case
if no reply.. try using another cable and check the connections
Sep 20, 2009 | Dell Latitude D600 Notebook
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Panasonic Toughbook CF-27 Notebook Logo
51 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
