Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Hi I have been bought a mcculloch 838 chainsaw but It won't start.I have followed the manual lots of times but no luck.I have a good spark and the plug is getting wet.it does look to wet but I'm not sure if it is to wet or not.it does still spark though.are there any screws that could have been played with to muck the settings up. kind regards Marc
  • 226 Answers
SOURCE: McCulloch 3200 takes many pulls to start, runs good when does.
I don't think I can help, but normal starting procedure for me is to put choke on, pull on recoil until it kicks over once. shut off choke and restart. Sounds like you have fixed almost everything & adjusted mag right. Rick
Posted on Apr 17, 2009
dontbother10
  • 2220 Answers
SOURCE: looking for a manual for mcculloch pm 484
If the ignition and fuel supply systems are good that is correct. I was not able to find a McCulloch 484. Are you sure that is the model number?
Lou
Posted on Dec 19, 2009
dontbother10
  • 2220 Answers
SOURCE: Mcculloch chainsaw. Model 2116av. Primer bulb is
Hello Jeff;
Your saw is listed here:
McCulloch MTD
Chainsaws 32cc-35cc-38cc Anti-Vibe
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations. The primer is displayed but not listed, and there is no part number. Before you get to deep please contact OrderTree.
http://www.ordertree.com/cms/parts-lookup-help/73.html
Use the IPL as a guide for disassembly/reassembly.
This is typical routing and a couple of hints.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
OMs for McCulloch are tough. harder than replacing the fuel line. Have your saw within easy reach they will want the serial number and a few other things.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
Good luck with your project. HTH
Lou
Posted on Feb 20, 2010
dontbother10
  • 2220 Answers
SOURCE: I am trying to obtain a copy of McCulloch 338 Chainsaw Manual
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Include your e-mail address in your request.
Posted on Apr 09, 2010
SOURCE: NEED INSTRUCTION MANUAL FOR MCCULLOCH 838 AS CHAINSAW
Found it at
http://www.mcculloch.biz/int/support/owners-manuals/?query=MAC+838&types=O
Posted on Apr 16, 2010
Testimonial: "Thanks exactly what i was after,thanks again."
McCulloch 320 chainsaw, won't start, removed spark plug, it was saturated in gas mix, how do I fix it? Guess I should ask if it's worth fixing first, lol...Thanks
If the saw had been sitting a while, especially without fuel stabilizer in the pre-mix,. change out the fuel and try a few more times.. it si a goof idea to allways use fuel stabilizer fro all the small engines..
Best regards
Ck
Sep 09, 2011 | McCulloch Garden
Need owners manual foer a McCulloch ms1839 av
Hi lorren333...
Go to the following webpage and download your user manual.
Please take time to rate me
http://lawnandgarden.manualsonline.com/support/mcculloch/chainsaw/chain-saw-manual-2424133
Aug 14, 2011 | Garden
Hello, I have a McCulloch 16" chainsaw, model 2618CAV, It starts but dies very quick, I've put in a new spark plug, checked the exhaust outlet for wasp nests, but it just won't go. can you...
check the compression on saw it has to have a min. of 110 psi to run properly...to do this you have to a compression tester bought at any auto parts store.. remove the spark plug and pull the pull rope 5 times this will give you the psi reading...
Jul 26, 2011 | Garden
Chain saw has been sitting at dads old house . hasnt been run in 20 yrs. mcculloch (mac120). no oil in it or gas or spark plug. how should i go about getting it to run ?? i know put fuel in it . but size...
Don't think you mean electric..Anyhow when adding gas for the first time start after 20years, add a pint of oil to gallon of gas. If it turns over and starts, then you can lean it down later. Google for spark plug or go to manufacturers site. good luck
Sep 20, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Manual for a 3616 mcculloch chainsaw
A link to a McCulloch M3616 follows:
http://weborder.husqvarna.com/order_static/doc/MOEN/MOEN2009/MOEN2009_545154712.pdf
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
iThank You for using FixYa.
Sep 05, 2010 | Garden
I need a manual for a McCulloch Timber Bear Model#60013414 chains
hi,
i believe this is the manual you are needing it is on ebay Item number: 150322102913 rtcurve.gif
good luck.
Mar 29, 2009 | Garden
McCulloch pro/mac 10-10 chainsaw owners manual & gas to oil ratio?
I have an old McCULLOCH MAC 10-10 chainsaw that takes 40-1 gas. Take the metal air filter cover off, and look on the inside of it, it should tell you all the info you need like starting it, what kind of gas etc,etc
Oct 03, 2008 | Garden
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
133 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
