Which no. toner is used in canon digital IR 2016 model.
    Master:
  • 149 Answers
GPR18
Posted on Oct 15, 2010
Canon ir 2016 toner bag full
I'm assuming it is the waste toner full message. Power down copier- Main Power. Open front door and gray handle to open left side door and pull out drum. On the top there should be an opaque disk to be removed and then you can dump the waste toner into the trash. BE VERY CAREFUL THIS COULD GET MESSY.! Slide the drum back back into position, close the left door and front door. Power up the copier and all should be good.
Mar 13, 2017 | Canon iR 2016i Black and White Copier
What is the problem when my canon ir-2016 says out of tonner
magnet roller poor contact on roller bush connector... other wise roller blade ya roller stick clean properly Nd cheek board connector.. otherwise the magnet roller is damaged... clean the full toner unit...
Aug 01, 2014 | Canon iR 2016i Black and White Copier
My photocopy, the iR 2016 does not read the amount of tonner. It sends a messege that the tonner is out while is half full.
hello.
you could try to remove the developer (is where you put the bottle of toner) and clean the toner that is in the machine and the contacts.
May 22, 2011 | Canon iR 2016i Black and White Copier
E019 in canon copier 2016 j.the machine runs n at last error comes E019, may be toner censer has problem how can i solve this.where would be the censer pls help me .
You need to replace the drum unit. The E019 error code means that the Waste Toner is full, but the problem with this model is that the waste toner cartidge is built in the drum unit so you have to replace the whole drum unit.
Nov 11, 2010 | Canon iR 2016i Black and White Copier
Copiadora canon ir 2016 muestra codigo e19 y suena
The waste toner needs to emptied out. It is in the drum unit and you most likely need a new drum unit. But you can empty the drum unit and turn the copier off then back on.... Good Luck Amigo
Sep 24, 2010 | Canon iR 2016i Black and White Copier
Canon 1r 2016 toner out indicator even after puting fresh toner,replaced dp unit still same problem
try to change the drum. (drum unit yield 50k)
can you tell me the total page number?
Sep 25, 2009 | Canon iR 2016i Black and White Copier
Copier model canon ir 2016 (down load stand by )
hi if yo have knowledge on electronics try to remove the boot rom and memory and let the machine for 10 minutes,then put it back the memory and boot rom,and turn on the machine.if the same thing try to update the firmware using sst
Mar 06, 2009 | Canon iR 2016i Black and White Copier
Canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Nov 14, 2008 | Canon ImageRunner 2016 Copier
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
18 people viewed this question
k24674
jasbo
jasbo
