Question about Airlink 101 AR675W Green 300Mbps 80211n Wireless LANFirewall 4Port Router
Loosing connection with a new HP laptop. I will be for connected and kickoff 4 times in an hour. Is there a simple fix?
  • Airlink Master
  • 7,733 Answers
Try some here..
Posted on Oct 15, 2010
Laptop sometimes switches off when moved.
Sounds like a loose connection where the laptop opens and closes hinge there are wires that run from the main screen to the main board. If you know how to take the unit apart it maybe a cheap fix if not then a new laptop maybe the way to go the prices have really dropped from 4 years ago
Jan 12, 2013 | HP Hewlett Packard Compaq 6720s Laptop...
Hp Xb3000 notebook expansion base
if you remove Mb battery for few min it will get reset
Aug 23, 2008 | HP Xb3000 Notebook Expansion Base And...
Hi. Our Advent Roma 2000 laptop seems to have a problem charging. Thought at first it was the charger so bought a new one, but still the same. The charging light flickers on and off as though there is a...
If you wiggle the connection to the laptop and it feels a bit loose, then the power connection on the laptop itself probably needs re-soldering. This is a common problem with laptops. Unfortunately unless you can do it yourself or know someone you can, then it will cost quite a bit to get fixed outside of warranty.
Feb 28, 2011 | Computers & Internet
Pavilion dv9308nr PC Notebook: hp dv9308nr wont power on all the time... works if...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP Pavilion dv9308nr Notebook
Some of my keys stopped working, yet if I press down in the left center under the keyboard then they work,, how do I get them to work all the time?? Replace keyboard??
You have an "open circuit" somewhere inside your keyboard - it could be a bad solder connection or a broken wire. In either case I would recommend a new keyboard.
Oct 31, 2009 | HP Pavilion ze2000 Notebook
My laptop isn't charging. I think the chargin port is lose. Is this a common problem? ANy fixes?
There are 2 common problems that end up with this.
1. Battery goes bad
2. Were ac plugs into unit becomes loose/damaged
There is no easy way to fix the connector is must be replaced by a laptop specialist and can get expensive. There are 4-6 connections holding the part to the motherboard and your looking at about 1/2 hour to 1 to just take the unit apart. Part general costs 12-30 bucks based on make and model. We have seen many of these come into our shop.
Thanks, Frank Z.
3868607368
http://www.attechcomputers.co.cc
Jun 25, 2009 | HP Pavilion G60-120US NoteBook
I can not connect a Viewsonic PJ260D project to Hp2140
Interestingly enough i simply rebooted and it workrd..... 4 hours of frustration solved by a simple task...
Jun 12, 2009 | HP 2140 Netbook
New Router and Laptop no wirless connection after 4 hrs .
There are a couple of ways to go on this one..first plug into the router with a netwrok cable, NOT via wireless.
If you have just opened the box on the netgear router you would need to configure some basic settings such as the SSID (name of the router) the country the router is in and maybe some type of security settings...often this cannot be done via a wireless connection at first, you must connect your laptop's netowrk port to a touter port on the rear of the Netgear. Open I.E. and navigate to something like http://192.168.0.1 (look on the sticker on the botton of the Netgear) setup the basics then try your wireless link using the settings you programmed.
May 10, 2008 | NetGear WGR614 Wireless Router
Airlink 101 AR675W Green 300Mbps 80211n Wireless LANFirewall 4Port Router Logo
100 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
