Question about Zanussi Dishwashers
Dishwasher-zanussi/electrolux goes through full cycle but hot water not available
  • 11,896 Answers
Check to see if the water valve is opening. The valve connects the external hoses to internal ones. The hot water valve may eitherbe bad or not getting any power to it which you could test with a voltmeter if you wanted to. Make sure both valves on your house water lines are fully open. You can remove the rear panel of the machine to access the valves.
Posted on Oct 15, 2010
What does c 2 mean on a ls 10 dishwasher mean brand is zanussi which was bought out by Electrolux
Water temp is too high or Boiler Temp setpoint adjusted above 90C in programming
Boiler relay welded/melted
Boiler water level sensor not functioning correctly
Aug 26, 2017 | Electrolux Dishwashers
Hi, my Zanussi zdf511 doesnt seem to be adding any rinse aid on any of the rinse aid settings?
Rinse aid dispenser can receive a maximum level of 140 ml rinse agent. Consumption rinse agent could be per wash cycle of 2 to 7 ml depending on the settings.
Thus 140 ml is enough for 20-70 wash cycles, depending on the degree of adjustment.
Dado
Dec 02, 2014 | Electrolux Genuine ZANUSSI ZDF511...
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Electrolux de 6850 dishwasher
I followed some of the good instructions already on Fixya. I had checked the heater and it was o.k. I then took the front door of the washer apart to get at the control box. Sure enough, I also had the common design fault. One leg of the rely had scorch marks and was now disconnected from the circuit board. I will solder tonight and test. I include a photo of the burned board. TNoel P8017c86.jpg
May 07, 2009 | Zanussi 24 in. DE6850 Free-standing...
Dishwasher not heating up
I found that resoldering the main PCB cured a dry joint and all is hot again
Apr 06, 2009 | Zanussi 24 in. ZSF6150 Free-standing...
I have a frigidaire electrolux dishwasher that won't shut off after it runs through the cycle...can you help?
If it keeps running, it's likely a faulty thermostat, thinking that the water isn't hot enough. They're located underneath the dishwasher. Part number is 154290204
Jan 09, 2009 | Electrolux Frigidaire Professional Series...
My dishwasher works but is taking a long time to finish the cycle it is a zanussi DA 6373
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Nov 12, 2008 | Zanussi Dishwashers
Dishwashers Logo
47 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
