Question about GE Profile 25.5 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
The freezer and the refrigeretor side are not cold the fan in the freezer is turning
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
Hotpoint refridgeerator side by side fan not working nor does the compressor?
First thing I'd do is defrost it completely, that means turning it off for a few hours with door open & letting the ice melt, you could be getting a buildup of ice in your freezer jamming the fan before the automatic defrost has time to clear it. Also check that the seals are sealing completely, (that can allow frost to form in freezer), if not use a hair dryer to soften them (gently) & mould them back into line.
Nov 19, 2014 | Hotpoint HSS25GFP Side by Side...
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
Control Panel show: Refrigeretor temp panel = all ligths OFF Freezer temp panel = all ligths from 1-5 =OFF 6-7 = ON ??? Thanks
You have a problem with the freezer fan motor inside the freezer. It is not circulating cold air up to the refrigerator section. You will need to determine if the fan motor has failed or has frozen due to ice buildup. You will need to remove everything out of the freezer including the drawer assembly and remove the back wall panel to gain access to the freezer fan motor.
Jun 28, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
I have an amana ASD2626hes side by side refer/freezer unti. REcently it soppted colling in the refer and the freezer was cold on the bottom only - top warm. I pulled the freezer inside coer - found the...
It could be either....
It is best to check and see if you are getting power to the fan...power to fan, the fan is bad...no power the board is bad...
heatman101
Apr 23, 2011 | Amana Refrigerators
Top of freezer is fine but the bottom isn't as
Sounds like your evaporator fan is not doing its job. The purpose of this fan is to move cold air from the evaporator coil (behind the lining of the unit) to the rest of the freezer and to the refrigerator.
The fan should be behind an access plate at the top of the freezer compartment. If it is running, you should be able to hear it. If you don't hear it, open the access plate and look at it. If the fan is not turning, you will need to replace the fan motor.
Oct 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Gss22jeta refrigeretor quit working
For a refrigerator to operate properly, it must: 1) have power to it; 2) the compressor (underneath the unit) must run; 3) the compressor fan (close to the compressor) must turn; and 4) the evaporator fan (inside the freezer unit, usually behind an access panel) must turn.
These would be the first things to check.
Oct 18, 2009 | Whirlpool GS6NBEXR Side by Side...
The food and drinks in the refrigerator does not feel and taste cold enough. The freezer is just fine.
Check for proper operation of the freezer fan. This fan moves cold air from the freezer to the refrigerator. If the fan is not turning, the freezer will be too cold and the refrigerator will not be cold enough.
The fan should be behind an access plate at the rear of the freezer. Listen for the sound of the fan. If you can't hear it, remove the cover and look at the fan. If it's not turning, you will need to replace the fan motor.
Oct 15, 2009 | Maytag MZD2766GES Side by Side...
Freezer has to be thawed out every 2 to 3 days. The refridgerator side isn't staying cool enough to keep milk from spoiling. It is a Hotpoint Model #HSS25GFTA WW and is only 2 1/2 years old. It is a side...
Could be multiple problems. First, check the freezer compartment and make certain that the freezer fan is running. This fan moves cold air from the freezer compartment to the refrigerator. If it's not running, inadequate cold air gets to the refrigerator.
Your having to defrost manually sounds like there could be a problem with the defroster circuitry; however, check out the fan operation first.
The fan should be at the top of the freezer. There is probably an access panel you can remove to see if it's turning. However, you should be able to hear it if it's turning.
If the fan is not turning, you will need to remove it and replace it.
Oct 11, 2009 | Refrigerators
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Oct 13, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile 25.5 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
56 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
