I have a CGL300TQ ventless propane heater. The thermstat quit working. I have shocked the thermostat bulb several times but it still does not work. The parts list shows part# slt545 or could be slt545 thermostat control vavle which I assume is the problem. I have called charmglow several times but I am told I cannot get this part. I do not understand why I cannot get this part to repair this unit. Can you help me. Thank You, Louise Kuhlman 419-655-3901
Therinnaiguy
  • 1420 Answers
SOURCE: What part do we replace first?
Door safety switch. You are sure you have power to furnace? jump out the G and R terminals on the furnace control board or turn your thermostat to Fan On to check. Make sure the door safety switch is in the closed position. Fan should come on. No fan, no power to unit. Check Emergency switch, circuit breaker and there may be a fuseable link in the wiring somewhere either above the unit or a condensate safety switch. Get power to the unit. Also check to see if there is a small fuse in the wiring inside the furnace or on the circuit board.
Posted on Jan 23, 2008
22yooper
  • 828 Answers
SOURCE: intertherm outside unit - s3ba-036k - does not run
Measure the voltage across the line. The outside unit normally runs on 220 Volts. Measuring each side of the line to ground will give 110 Volts. If your outside disconnect is of a fused type one fuse could be blown. If a fuse is blown on one side of the line you will read zero volts differential across the line.
Check the type of fuse used in the disconnect. Make sure the proper size time delay fuse is installed on both sides of the line at the disconnect.
Posted on May 17, 2008
muttandjeff
  • 359 Answers
SOURCE: thermostat in motorhome quit working
try removing power from t-stat and leave off for one minute and power back up see if resets
Posted on Nov 24, 2008
kdgrayson
  • 195 Answers
SOURCE: Gas vavles is letting propane gas through the gas control vavle.
If you have propane you better not mess around! with nat gas its lighter than air and drafts or flies away if it can.
not so with propane , its heavier than air and stays down low!! and the most explosive situation is 10% gas/ 90% air !!!! so a small leak??? there is no such thing with propane!! turn off all valves to it and get it fixed by expert this is one repair a handyman should never do!!
Posted on Aug 25, 2009
SRF518
  • 232 Answers
SOURCE: I have a Charmglow CGL250TE-C .. ventless propane
go to this site
http://www.desaparts.com/
Posted on Oct 21, 2009
Charmglow ventless lp gas fireplace model CGL300TQ pilot light wont stay lit, how do i know if its thermocouple or regulator?
if the therocouple has packed up pilot light will not light thermocouple has long small diameter pipe leading to a larger end this needs to be above the pilot flame also for safety have a small bowl of soapy water with a brush wet the nut with soapy water in no bubbles appear then try lighting heater thermocouples don't last that long
Jan 26, 2013 | Rheem 36" Water Heater Thermocouple Kit
Emberglow ventless gas logs (set to burn on porpane gas). Pilot lights, but not logs.
It needs 14'' wc to work , hose could be too small for load .
Dec 06, 2012 | Heating & Cooling
Bought a brand new Williams wall heater a month ago "converted" for propane. It worked great for aprox a month now it wont come on. The piliot is lit but just wont come on?
check thurmostat. check low voltage. check limit switch there may be several.limits should be closed. I usually push re set first, if there is a click,then switch was open.limits trip when they get too hot.is this ventless? is the vent o-k?
Dec 23, 2010 | Heating & Cooling
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Oct 17, 2009 | Dyna-Glo Heating & Cooling
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
135 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
