Question about ViewSonic VX922 19" Monitor Flat Panel
Monitor goes in powersave mode and I can't get it to restore
  • 11,361 Answers
Try it with another PC to make sure it is not PC problem, if it is the monitor, then you will have to troubleshoot it. See failed VIEWSONIC due to bad caps.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 16, 2010
SOURCE: URGENT Big project due...Monitor won't stay on...light goes yellow after initial message c below
i checked cable lots of times. even i tried DVI-D connector but it is still same.
Posted on Feb 06, 2008
  • 78 Answers
SOURCE: LG1717S powersaving mode problem!
Have you tried to disable the pwer saving mode and see what happens. What operating system do you have on this laptop please ?
Posted on Mar 07, 2009
SOURCE: monitor goes to powersave mode in the middle of
set yor computer power setting as presentation and it will work 24*7 and wont go for sleepor hibernet mode
Posted on Oct 02, 2009
  • 10406 Answers
SOURCE: LG stuck in powersave mode
Connect it to a different computer, e.g., a notebook computer,
and set the screen-resolution to 800-by-600, and see if the monitor works.
Change the screen-resolution to 1024-by-768, and try again.
Change the screen-resolution to 1280-by-1024, and try again.
Connect a different monitor to your computer,
and set the screen-resolution to 800-by-600.
Then, disconnect the "alternate" monitor, and connect your monitor.
Posted on Nov 25, 2009
  • 10406 Answers
SOURCE: I have an older Dell Ultrasharp monitor that is stuck in Powersav
Check that the "data" cable is tightly-connected at both ends.
Connect the data-cable to another computer (laptop?) to see if it works with the laptop.
Try another monitor with your computer, to see if your computer is putting out the correct video signals.
Posted on Jan 01, 2010
When i turn on it goes start to pc entering power saving mode
Are you sure it isn't the monitor entering powersave mode?
An unhooked monitor (especially flatscreen DELLs ) will go into powersave mode if it isn't getting a signal but is getting power.
First unplug and then replug your monitor. Both ends of the cord, the end in the back of the monitor (if it comes out at all) and the end that plugs into the computer.(unplug it from the wall first)
Reboot computer.
If that fails...(and you do have a video card)
Unplug everything from the computer, open the box, ground yourself by touching the metal frame of the computer case and reseat your video card....you may have to undo one screw to get it out.
DON'T drop the screw into the case!
Put it all back together and try again.
If that all fails Boot Windows (windows right?) into safe mode and change the power settings for the monitor...perhaps something got changed or broken by an update.
If that fails....
Get Linux.
TickMagnet
Aug 17, 2011 | Gateway 505GR PC Desktop
Dell E228WFP keeps entering powersave mode
disconnect all the cables from the back of the monitor except the power
you would see a test screen
if it still go to power safe while you are in the test page you monitor cud be bad better buy a new one as usually repairs are expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Screen randomly goes into powersave mode????? For no reason into switches off & i have to reboot to get it working agan???? Help!
well you can increase the time limit of your powersaver setting or you can even disble it. if this doesnot work then try to get it repaired
Aug 01, 2009 | LG L1718S (Silver) LCD Monitor
Mar 07, 2009 | Computers & Internet
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
POWERSAVE
I have A "Dell" E152FPc, and I have found an open transistor (Q201) on the Power Supply Board. My monitor comes on nice and bright for approximately 2 seconds, then goes dark; the power LED is steady. The voltage to the PWM IC is waky.
Before you try any hardware troubleshooting go to your control panel and turn off any power management options.
May 26, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Powersave
If it's going into powersave mode, it usually means it's not getting a signal from the video card. Try plugging this monitor into another machine or laptop and you should be able to tell if that's the issue.
May 26, 2008 | Dell E171FP 17" Flat Panel LCD Monitor
Sony SDM-HS74P 17" Monitor goes black after turning on
Most likely you inverterboard went bad on the monitor.
Nov 04, 2006 | Sony SDM-HS74P 17" LCD Monitor
ViewSonic VX922 19" Monitor Flat Panel Logo
65 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
