Question about Whirlpool Duet GHW9150P Front Load Washer
Front Load washer
What does F11 stand for. My washing machine starts then the prompt flashes with beeps.
  • jeff83 Jun 09, 2008
    I got the f-11 code also, had the wiring harness replaced and it still isn't working right...paid a $1000 for this piece of ****!!
  • 19 Answers
FAULT CONDITION WHAT TO CHECK
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
A list of all fault codes for whirlpool duet; click on link. Hope this helps.
http://www.repair-help.com/kb/index.php?article=544
Posted on Jun 08, 2008
My washing machine will lock the door, start the cycle and within a minute, it will start beeping and flash an F, then an 11. At this point, I will hit the cancel button to break the cycle. Sometimes,...
The F11 error code is a communication failure between the 2 control boards. This includes both boards & the wiring harness as potential defective components. However, this is usually the main machine control board that needs replaced.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When pushing start, washer beeps 3 times but won't start
Is the machine showing a "code" like FdL or F11 in the window where the numbers count down? The machine won't start because it thinks there's a problem. FdL and F11 are often times the codes most displayed when the machine beeps and won't start. FdL means a door lock problem and F11 means a motor or motor control board problem. If it's flashing either one of those codes the problem is most often the CCU circuit board in the machine (inside, top, back, plastic case) The CCU circuit board has what's called cold solder joints causing bad communication between the CCU and the door lock and/or the motor or motor control board. The cure for this is to remove the case with the circuit board then remove the circuit board and resolder the points on the circuit board where the spade connectors and relays (5 of them) connect to the circuit board. If you're good with soldering techniques the job is easy. If not, take the board in the case to a good appliance repair shop (along with this response) and they should be able to help you out. Good luck.
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My dryer starts up for less than a minute and than starts beeping and all lights start flashing. For a while i was able to change settings from 60 mns to towels and it would work. Now it starts for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2010 | Dryers
Washer worked fine early Sunday, then Sunday evening I was washing and kept getting this F11 error. It now has standing water inside of the washer and when I press the button to start the cycle the motor...
F11: Pump related. Pump not able to empty water correctly. More blockages to check for: something inside the pump stopping it or reducing it speed. Sump hose blocked between the outer drum and the pump. Outlet hose blocked between the machine and the U-BEND. The pump could also be weak, pumping too slowly, or intermittent.
Feb 24, 2010 | Washing Machines
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
The washer beeps and flases f dl
it probably flashes also f11....to correct that problem , you must replace CCU board (upper board) and latch assembly...
F11: CCU board
FDL: latch problem
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
END OF CYCLE KEEPS BEEPING WHILE WASHING
Maybe the machine is telling you that your load is uneven, When going through a spin cycle it will detect if the load is too heavy on one side. Just open the door and spread the load evenly. good luck.
Jan 26, 2009 | Whirlpool LHW0050PQ Front Load Washer
F11 Error
probably bad control bd remove top control mounts to rear rail ck all wiring to control first just f11 usually indicates internal control failure
Nov 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
155 people viewed this question
Dan Webster
Dan Webster
Sal De
