Question about Whirlpool GU2400XTP Built-in Dishwasher
The dishes still have a soapy film on them even after Sani-Rinse.
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101 .
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 16, 2010
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Its not soap. it is a mineral caused by hard water.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Posted on Nov 06, 2010
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
There is a soapy film on dishes and they are not getting clean, food is stuck on all dishes even after rinsing dishes and running cycle more than once
Change your dish washer detergent ... try something else ... could be a water problem ... but do the simple things first ...
Do you use a rinse aid product?
Nov 24, 2010 | KitchenAid Dishwashers
The dishes are still wet after "drying" overnight?
With the energy efficient dishwashers today it is very important to use rinse aid for proper drying. The rinse aid will help sheet the water off of the dishes prior to the dry cycle. If you do not use rinse aid you can expect poor dry performance.
Next to the detergent cup in the door is the rinse aid dispenser, be sure it is full. You only need to fill it about once a month. There is also a product called "Turbo Dry" that you can use in the rinse aid dispenser, it helps dry even plastics very well.
Next be sure you have selected heated dry on your options.
Sani Rinse will also help as it heats the water before the dry cycle.
Let me know if you have questions.
Aug 01, 2010 | Whirlpool DU1055XT 24 in Builtin...
Doesn't drain; glasses have film; rinses with used, soapy water
The white film problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 02, 2009 | Dishwashers
Dishes are coated with soapy film after full wash cycle
The problem is not your dishwasher but rather the water going into it. Hard water when heated up in a dishwasher dries with calcium and magnesium spots(often looking like a white residue). There is a product out there just for this problem and its called the dishwasher filtration system. It filters the water going into your dishwasher solving this problem once and for all. It is very affordable(like 70 bucks) and has a money back guarantee. You will not want to return it trust me. after the first load you will be amazed. www.dishwasherfilter.com is where you can get it.
Jul 05, 2009 | Kenmore Dishwashers
Dishwasher rinse water is soapy
if you noticed the white film after they were dry it's your water if not reduce the amount of detergent i prefer the powder mysef
Feb 20, 2009 | KitchenAid Dishwashers
Soapy film left on dishes
Turns out it was my water softener leaving hard water on my dishes...now I have to fix that.
May 18, 2008 | Dishwashers
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
HElp Dishes not coming clean
Whirlpool GU2400XTP Built-in Dishwasher Logo
497 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
