RE: Repair External Hard drive
Dear Expert
I have 250 GB maxtor e-sata hard drive, can also connect with usb. I can't see the drive in my computer, But i can see, when i select my computer than manage and then storage as unlocated drive, but i cant format the drive for some reason.
I use OS - Windows Vista Home Premium with 1.86MHz Processor speed, RAM 1.49gb and 120gb hard drive
I would be realy appreciate your help
Thank You
  • Jonathan Dator May 11, 2010
    when you get into manage and select disk management... you need to allocate the some space for use then that's the only time you can format or assign a drive letter and use it.
  • 66 Answers
Any luck?
Posted on Jun 03, 2008
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
How to repair the usb port on maxtor one touch 120GB external drive
You cant repair USB its to small to resoldure unless you are PRO, you could take it apart and connect it to a computer or another laptop and pull out the data here is a guide. http://www.gearhack.com/Forums/DisplayComments.php?file=Computer/Reusing_the_Maxtor_OneTouch_III_Mini_Edition_Portable_Hard_Drive
Mar 06, 2011 | Maxtor OneTouch III Mini Edition 120GB...
How do I install my320 GB Diamond Max 21 internal Harddrive setup as a external drive with USB 2.0 to computer, The S/N is 9QF09BA4, STM3320620A and firmware3.AAE Date Code is 07143. I have two that I...
I am unsure if you are trying to take a currently external drive and mount it internally, or if you are trying to make an internal drive into an external. Please clarify.
Feb 13, 2011 | Maxtor 7L320S0 320GB 7200RPM 16MB SATA/150...
Will not recognize sata drive need to know necessary connections
There are only two connectors on a SATA drive, namely POWER and DATA.
Check that both cables are securely connected.
Try the disk-drive in some other computer.
Nov 02, 2010 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
BROKEN PLUG?
You can buy another external housing and then just swap the hard drive itself over to the new housing. The housing only cost in the 30 buck range if not cheaper. If you need to get the data off, you can also buy an EIDE/SATA to USB adapter that will allow the connection between an unhoused hard drive and a computer. CompUSA sells them for around 20-25 bucks.
Jul 05, 2010 | Maxtor OneTouch III Mini Edition 120GB...
I had problems with my Maxtor One Touch III Mini. It was a loose connection from the USB cable on the Drive's end, and when I tried to solder it, I damaged the connector. Is there an alternative to get an...
If you damaged the external case you have two options. Remove the drive from it and put it in a new external or put the drive directly into your computer.
Here is a guide that will show you how to open your case.
If the hard drive is a SATA DRIVE you can just plug it right into your computer with SATA cables. If your drive an IDE DRIVE you're going to have to find an adapter in order to plug it into your computer as the IDE connection on these smaller drives aren't the same size as the connections on normal sized drives.
The easiest solution would be for you to find out what kind of drive it is, and then buy a compatible external case to put it in.
Mar 03, 2010 | Maxtor OneTouch III Mini Edition 120GB...
Was sent my old internal harddrive after a warranty service to make a backup from and i want to know what connection i need to make it usb. 5K250-250
you can purchase a huge range of drive interfaces from your local computer store. Make sure you get an interface, or USB external case to suit the drive interface ( PATA or SATA ) plug the ting in and connect to your pc through a usb port... then I would copy the entire drive contents onto another drive..
Nov 02, 2009 | Hitachi Travelstar 5K250 HTS542525K9A300...
Maxtor 250 GB SATA problem: Foreign disk problem
Simple you need to update your bios by downloading bios updates for you motherboard. Then it should recognise your HDD. The yellow triange just means your mboard does not have the necessary drivers to recognise the device. thanks
May 19, 2008 | Maxtor (6B250S0) (6b250s0-20pk) 250 GB...
Maxtor external hard drive
The drive is dying. If it is still under warranty, call Maxtor for a replacement.
Dec 13, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
