Question about Philips 50PFP5332D 50 in. Plasma Television
How do I set up a split screen to view two different channels at once?
  • 4,339 Answers
There are two parts to this, first you need to have picture in picture. No got, then you cannot view the two at once. Then, you need two input sources, like tuner and dvd. or two tuners.
Posted on Oct 15, 2010
Vizio tv to split screen for security cams
The split screen view comes from the recorder. If you have no recorder then you'll need to invest in what called a Quad to view all four cameras at once.
Jan 14, 2014 | Vizio E420VA 42 in. LCD HDTV
How do i remove the split screen from a sony trinitron xbr without a remote
Cannot be done and if older set you need the original remote--Sony had several different ones for different models for this--at our shop have a complete collection of them as needed for this kind of issue and others.
Apr 21, 2012 | Televison & Video
How do I record two channels at once on a DMR-EX773EB DVD Recorder
I cannot find on online manual for this model. If dual channel recording an actual specification for the model? If it really should be able to record two channels at once then it may be similar to the DishNetwork DVR. It has one input but internally splits and creates two different outputs for two different channels.
Check to see if there is a mode setting for single/dual. You will need to set it to "dual". The Dishnetwork DVR has what it calls TV1 and TV2. You can record to TV1 but cannot watch a different channel on TV1 while it is recording. You CAN however watch and record a different channel on TV2 while TV1 is recording. (and vice versa). You can also record two shows while watching other recorded shows.
I'm guessing that you may need to look for some recording options to be able to record two channels at once.
Mar 21, 2011 | Panasonic Televison & Video
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
How do you split the screen to watch two different shows at once?
to watch two defferent channel in one screen,u just need to activate the PIP feature of you tv..PIP means picture in picture.
May 20, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Can only see an image using Twin View and colors are distorted
Ur convergence it dead.Know how to solders?Try these websites.Tv repair world.com,Tv Repair kits for convergence kit,use what in that kit.
Oct 30, 2009 | Sony KP-53HS30 53" Rear Projection...
On my cyberhome 1600 dvr want to view tuner of dvr on tv screen
Take your TV for a check by a good technician. Some IC have short circuited in the accident that occured.
Rate this...
Mar 22, 2009 | Cyberhome DVR 1600 DVD Recorder
Full screen viewing on 52" LCD
The new tv we bought has a setting for 'theater' settings. These are different settings in which to view the non high def channels and shows.
Aug 29, 2008 | Sony PlayStation 2 (PS2) Console
JVC Television 56" in Digital Mode
somewhere in the tv's menu there will be something called autotune or channel settings. while in that part of the menu you should find something to change settings. also there are many inputs on the back of big screen tv's, you might try a different input like cable/antenna for instance. it may take a two way splitter to split the signal for both digital cable and analog cable. by next february the analog part of the cable may not work anyway.
May 02, 2008 | JVC AV-56P575 56" Rear Projection...
Philips 50PFP5332D 50 in. Plasma Television Logo
218 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
